NeverGoBack88
Greetings,
Wondering if anyone has experienced this, something similar, or any thoughts on the cause or a solution. At my wife's office, on an iMac G4, using Toast Titanium, the optical superdrive still writes audio and other format discs properly, but just recently began having consistent trouble writing data format discs to CD-R successfully. Latest symptom is the typical message that appears when a lead-in / lead-out writing error has occurred. On mine at home, that occurs every once in a great while and is assumedly the occasional bad CD media, solved by trying another. We all use similar models at home, are quite familiar with Toast software and have not had this trouble, machines are kept clean and utility maintenance software run regularly. It would seem very unusual to that 6 to 8 discs in a row would fail. Or is it? Thanks for reading!
