Hi and thanks (again) for the warm welcome... Things aren't
that complicated, just more/new tasks at work with
less pay :-/ but still can afford some hobbies anyway.
Back to our thread, I've been experimenting a bit with the
IIsi and the
Radius Pivot PDS card... first of all, after this period of inactivity, the PSU is misbehaving a bit -- things like firing up on just plugging and then not powering off (yes, the power button is
not at the stuck "server" position) so it's asking for a recap at some point... however, after some warm up period it seems to do just fine for the testing.
To summarize, here are the test conditions:
- Mac IIsi with 33 MiB of RAM, 250 MB HD (stock ROM)
- System 7.5.5 (pretty barebones)
- Apple 12" RGB monitor connected to the built-in video port (to see what's happening!)
- Acer LCD wide-monitor (vintage Mac friendly)
- My Radius ColorPivot IIsi PDS card
- My crude connector (but continuity checked out OK) now with all relevant lines
- 10-dip VGA adapter (the best documented one I have, see my previously posted bottom-left adapter)
Now, the bad news
I can only get the IIsi (with the Radius) to boot
after a really cold start (
powering off for a couple of minutes won't do), otherwise after the RAM test (takes some time for 33 MiB :I ) the dreaded
Death Chimes are heard (with just a standard pattern on the 12") xx( The few times it boots (from cold) no card is detected by
SlotInfo, or the
Monitors control panel. In this state, the Radius card itself seems to output some signal (64 kHz horizontal and a rather odd
69 Hz vertical, as stated by the Acer monitor and confirmed by the 'scope) but the image itself mostly consisting of a dot pattern, sometimes moving in a randomly fashion -- but somehow affected by user interaction :?: Tried on another working IIsi I have (9 MiB RAM) but got the very same behaviour...
Then I tried what I suppose to be a
very similar card, except for the interface: the
Radius Pivut NuBus -- same big chips, same VRAM, even the
declaration ROM has
exactly the same contents (have read both with my EPROM programmer). But this card has the usual DA-15 monitor connector, making things much easier. This goes of course thru the NuBus/FPU adapter I have, tested good with many other cards.
No boot problems here... but regardless of the sense code applied (tried the whole list above) this card
always output the aforementioned
64 kHz horiz./ 69 Hz vert. sync signal, which my Acer monitor mistakenly identifies as "1440x900" and the auto-adjust feature can't center properly -- but the image is definitely present and readable. However, with some DIP settings the
640 x 864 (as
Monitors indicate) desktop looks heavily stretched as expected for a
portrait mode on a
wide screen; but some others give the same sync signals but a
tilted desktop, this time identified as
864 x 640.
Further investigation makes me think that the
only sense line checked by the card is
Sense Line 0, that is, pin 4. And it only switches between "regular" portrait mode and the
tilted one, but no other modes are generated -- somehow reasonable because of the only Xtal on board. However, my previous testing with that very same card revealed the availability of a few "standard" screen modes, which I can't get right now -- most likely because I used another adapter back then, which (if memory serves) is currently installed on Dad's 7500 and thus far of my reach...
Anyway, if we assume both cards (
Pivot IIsi and
Pivot NuBus) are
the same with just a different interface (which seems reasonable) then that very different behaviour is highly suspicious... maybe I had the bad luck of getting the only malfunctioning unit of these PDS cards, or simply I broke it at some point :I However, I won't rule out that hte card's hardware is fine except for those !"$%&@# PLCC sockets for the decl. ROM, which I know to be "temperamental", to say the least... I did have some troubles reading the ROM, in fact. Will try to clean & tighten that.
Or maybe they're
not the same and I'm doing something wrong with the PDS version... or some software incompatibility (?)... I'm not using any specific extension, but I was hoping the card would be accesible for the desktop, if not getting all of its capabilities.
After I get the PLCC ROM socket revised, I'll check again and let you know.
