That would certainly work. There are people on this board including myself who would like to try to fix it, but depending on who you send it to and what's wrong, it may not get fixed, or it may take more time than expected to figure out what's wrong. If I were you, I would ask in the trading post to find someone to fix it, and get general quotes on shipping, fixing it, etc.So what's the fix to something like this? Complete replacement of the power supply?
Tempest
I would agree with that. The cost of finding another powersupply or Mac II, is probably less than having someone fix it. Does the guy you got the IIfx from still have any Mac II's?That would certainly work. There are people on this board including myself who would like to try to fix it, but depending on who you send it to and what's wrong, it may not get fixed, or it may take more time than expected to figure out what's wrong. If I were you, I would ask in the trading post to find someone to fix it, and get general quotes on shipping, fixing it, etc.So what's the fix to something like this? Complete replacement of the power supply?
Tempest
Another option would be to get a working power supply and then sell your bad one to one of us. This could also be facilitated in the trading post. I'd say that's a better option, possibly less expensive too. No risk of expensive labor or needing strange parts. You know you'll have a good power supply. You pay shipping only one way. etc.
Yeah he had two Mac II's and another IIfx. Are we sure the Mac II power supply is compatible with the IIfx? I thought the IIfx one was different (a variable speed fan or something).Does the guy you got the IIfx from still have any Mac II's?
Yup, it's compatible... it just won't have the variable speed fan (ie. single speed). Apple's upgrade path from a Mac II to a IIfx was a motherboard replacement and did NOT include a power supply. All of the voltage outputs are the same.Yeah he had two Mac II's and another IIfx. Are we sure the Mac II power supply is compatible with the IIfx? I thought the IIfx one was different (a variable speed fan or something).Does the guy you got the IIfx from still have any Mac II's?
Tempest
That sucks...I got a working power supply from a dead IIfx and it is giving the proper voltages. Unfortunately I'm still not getting any disk or HD activity. However I took a closer look at the board I think I may have discovered the problem. The trace on the top of the board on the left side that goes from the capacitor(?) at C45 to the spot below the second Nubus slot labeled FD15 (between zones N2 and K2) is completely burned out. It looks like it took a hit or something in the past. I'm not sure what this trace connects, but I'm guessing it's needed since it seems to come from the power supply.
I think at this point I'm SOL unless there's an easy way to repair such a thing. As a consolation though I got two nice looking Mac II's from the guy (for parts in case this power supply was also bad), another video card, and another full set of IIfx memory. So I guess even if this IIfx is dead I can at least make my money back selling the memory. A Mac II isn't too bad for a gaming machine I suppose. At least not for the stuff I want to play.
Tempest
The Mac II and IIx power supply a single speed fan. The IIfx has a variable speed.The Mac II had a variable speed fan.
That's contrary to Usenet posts which I have read regarding the subject.The Mac II and IIx power supply a single speed fan. The IIfx has a variable speed.The Mac II had a variable speed fan.
Interesting... I'll have to look up a Mac II manual to check that. However, even the person that posted that says he's never heard it speed up or slow down.That's contrary to Usenet posts which I have read regarding the subject.The Mac II and IIx power supply a single speed fan. The IIfx has a variable speed.The Mac II had a variable speed fan.
Re: Mac II fan noise - an unauthorized solution - 17 Jul 1988 6:17 pm
In the Apple service manual the II and IIx have a different part # than the IIfx... Power Supply 661-0375 (II, IIx) 661-0542 (IIfx).Although appearing identical to the Mac II and IIx, the IIfx power supply has a variable speed fan to better control noise and cooling.
I believe there may be a short circuit somewhere. It caused the trace to burn and also burned the power supply. So the next step is to test nearby capacitors to see if they are short circuited. Once you successfully find and remove the short circuit...The trace on the top of the board on the left side that goes from the capacitor(?) at C45 to the spot below the second Nubus slot labeled FD15 (between zones N2 and K2) is completely burned out. It looks like it took a hit or something in the past. I'm not sure what this trace connects, but I'm guessing it's needed since it seems to come from the power supply.
That's actually not a bad idea... and probably the safest way to troubleshoot the problem if you choose to do so.The easiest and fastest solution is to run a wire directly from the yellow wire on the power supply to the yellow wire of the hard drive power connector. This would effectively bridge the gap, wherever it may be (probably this burned trace), and cause the floppy to come to life as well.
You can use a continuity tester. Most multimeters have this function, sometimes it's called a diode tester or uses any variety of weird symbols. It's usually the function that looks different. Touch the probes together and the readout should change.How would I figure out where a possible short is?
Running a wire directly to the disk might solve the problem, but that's still a hack and not a fix (remember the HD wasn't spinning up either). Once I'm sure there's no short I might just try bridging the short with a wire and see what happens.
Tempest
