IIci / Quadra 700 power supply from PM 7100?
Tx76
Hi there!
after the PSU of my Quadra 700 died, I replaced it with one from a IIci (which is obviously the same), but it died too (two capacitors exploded). I will try to recap it, but I also have a PSU from a Power Macintosh 7100 lying around. It fits into the IIci/Quadra physically, but has somewhat different specifications (see photos, the one with the higher voltages is from the 7100).
Will it work or will it fry the Quadra?
Tx76
I can't even remember which PSU is the one out of the 7100 any more. Its in a IIci somewhere.
Thanks again! I was worried about the different voltages shown on the label. But I don’t even know what they refer to…
The voltages are the same on both? Do you mean the currents? They are the current rating. Basically the top photo is a higher power powersupply, thats the only practical difference. It can drive more stuff / its better.
Tx76
Thank you!
volvo242gt
Have the same C/Q650/7100 power supply in my IIci right now. Works fine. It's just a higher wattage/amperage version meant to power two SCSI devices instead of one.
joshc
Yeah these are interchangeable.
The PSU connector/pinout is shared between these models: IIcx, IIci, Quadra 700, IIvi, IIvx, Quadra 650, Centris 650, Performa 600 Power Macintosh 7100. The 650/7100 one is a bit higher rated as mentioned above.
olePigeon
@Tx76 There's also a free design for an ATX to IIci adapter. Includes soft power so you can still turn it on via the keyboard:
If you download the "alternative" design and upload it to your favorite PCB maker, they can preassemble everything for you. I had 5 made for under $12 at JLCPCB. I found JLCPCB really easy to use compared to PCBWay.
Tx76
That's also very interesting, thanks a lot!
