Sludgedragon
Got burned out trying to ressemble my Pismo, so I took a Lombard on my long trip. It worked great, without giving me a bit of trouble, but it became a big weight to carry around and I had to switch PC cards in and out of it. So I have just bought myself a nice iBook G3 600, I believe late 2001. Just $129.99 plus $22.00 shipping. It's now running 10.3.9. I put in the Airport card I had bought for the Pismo, and eventually I will increase the RAM from the current 256, but that can wait.
Interestingly, when I check on MacStumbler, I get a much higher signal number for all visible wifi networks than with the Lombards or Pismo. Mine, in the same room, is now 110 and blue, when the best it would do in a Lombard is like 60 or 70 and green. Is it the bigger antenna in the lid? or just a younger, stronger machine?
I also noticed that when I was installing updates to take it from 10.3.3 to 10.3.9, the wrist rest over the hard drive got plenty warm, about as hot as the outside of a cup of coffee. Is that normal for these? I also looked up how to replace with a bigger hard drive, and it looks like you have to just about take the whole thing apart, so I guess I'll stay with the 20 GB for now! The only problem so far has been that I tried to network it with the iMac G5 by Ethernet and they didn't see each other, although the same cable connected my Lombard to the iMac just fine. Will have to look into that one.
