HTTP block device driver
bbraun
Well, I've got a working HTTP block device driver. Woohoo.
Basically, it's a block device driver that takes a file on an HTTP server, and presents it as a disk to macos. Access to the "disk" is translated to ranged HTTP GET/PUTs.
I've put a 500MB minivmac disk image on my apache web server, and have mounted it on my pb540c (using the AAUI -> UTP -> Netgear wifi adapter from here) running System 7.6.1 + OpenTransport 1.1.2. The driver is only using MacTCP (.IPP) device driver calls, so it should be fine with MacTCP instead of OT.
This is just kind of the initial proof of concept right now. The IP address of the server (MacTCP's DNS from within a device driver is bad news), server name (for working with http virtual hosts), and the file path are hard coded in the driver at the moment.
I'll try to figure out a control panel and prefs file to be able to configure that stuff.
The snapshot of source is here if anyone is interested.
dougg3
Wow! That's a great idea. I've tried setting up AppleTalk on Linux so my Mac could access it (and failed), but this approach you've come up with would be much easier to set up. Cool!
bbraun
I haven't run any performance tests at this point. I expect it's abysmal performance, that's why we're using 20yr old gear, right? ;)
This is currently opening & closing the connection with every request, simply because it was the easiest to get going. Eventually, attempting to reuse the same connection would be an improvement, although it'd then need keepalives, connection close & reopen handling, etc.
But, I don't expect great things from either MacTCP or OT1.1.x.
My particular goal here was to get reasonable storage expansion without AppleShare, since AppleTalk is not routed over most modern wifi AP's, since I usually do most of my classic mac stuff from my pb540c. You'll probably still want to put your normal working set on local disk, but this provides easy access to remote archival storage, and exchange with emulator storage. It has lots of other potential, from read-only classic mac friendly archives on the web, to potentially migrating off MacTCP to direct Enet driver usage for diskless booting off the internet.
Anyway, I'm reading about Control Panels now, so maybe I'll get a configurable interface to this in the next couple days/weeks. Hopefully before I get one of dougg3's ROM SIMM programmers, when I'll be distracted by that project again. :)
techknight
nice, bringing the "cloud backup" to older hardware :)
diskless booting over the internet would be cool as hell, would eliminate the need for unobtainium SCSI hard drives. I know some modern google laptop setups used to boot from the cloud.
Just put the driver in ROM, and interface it to PRAM. use a control panel to setup PRAM with the parameters to connect to the "startup disk" and reboot. it boots off the web :) This is something i would HIGHLY support for my personal usage, is network booting an old mac.
bbraun
Control panel added, along with a demo video.
It's still very unstable, don't use it for anything important, etc. It frequently hangs and I've left Debugger() statements in the error conditions as I'm still trying to debug the thing (Debugger() statements cause it to break into macsbug. If you don't have macsbug installed and it hits one of these statements, you'll get an Unimplemented Trap bomb or something).
But, it's working mostly well enough to get the general idea.
bbraun
More progress. The networking code seems to be working reliably now, but I'm doing some known bad stuff in my interfacing with the system, which I'll need to restructure some code to get working right. At that point, hopefully this will be reasonably usable.
bbraun
I've got the driver working surprisingly reliably now, latest version here
I can copy applications (testing using ResEdit), open the applications on the HTTP Disk, do directory listings, copy files to and from, open & edit files on the disk, etc. without issue at this point.
The macsbug debugging calls have been left in still, so the previous disclaimers on that still apply. They're only in error conditions, and I haven't hit any on my test environment (supporting both read & write) recently, so it does seem fairly reliable.
There are 3 parts to this:
1) The driver. When the driver is opened, it takes some parameters such as the address of the server, the name of the server (to work with ghosts), and the file path on the server. It then does a HEAD request to figure out how big the file is, creates a DriveQEl structure, adds it to the drive queue, and posts a notification that the drive has been attached, and returns to the caller. The system processes the posted diskEvt, does some control calls to get the default icon and some stuff, and then goes on with the reads & writes. The driver then translates the reads & writes to HTTP ranged GET and PUT operations. If the file is not writeable, the PUT operations fail with writErr. The driver exists as a DRVR resource within the Control Panel.
2) The INIT/System Extension. This loads the driver on boot. It only loads the driver, doesn't open it, so the driver is basically doing nothing in RAM. This also displays the Control Panel's icon during the boot process. The INIT is just a resource in the Control Panel, not a separate file.
3) The cdev/Control Panel. This is still a pretty rudimentary UI that asks for the hostname & file path of the file to mount as a disk. On open, the Control Panel opens the DNS resolver (finds a resolver resource in MacTCP or TCP/IP control panel, or MacTCP DNR file inside the System Folder). When you hit the "Mount!" button, it attempts to resolve the hostname, open the HTTP Disk device driver (named ".Webdrv") that was loaded by the INIT at boot time.
There is currently no error reporting by the Control Panel, so when it has problems with opening the DNS resolver resource, or resolving the hostname, etc. it just seems like nothing happened. I usually close the control panel, reopen it, and try again. Fixing this is on my TODO list, but my focus has been getting the driver working reliably. Now that it seems to be working well, I'll try to focus on getting the Control Panel nice and pretty.
The "known-bad" things that I mentioned the driver was doing before was calling MacTCP synchronously. MacTCP is its self a device driver, which then calls the ethernet (or appletalk, in the case of MacIP, or modem or whatever is backing the connection). So when my disk driver called into another driver synchronously, and that driver then calls into other drivers, it would occasionally deadlock the system. The badness of this is described in this tech note. So, I had to restructure/rewrite my straightforward MacTCP calls as an asynchronous state machine. Once I did that, the deadlocks disappeared, and I was able to better handle large read/write requests. I've noticed the File Manager during file copies and other operations can request 256KB in a shot, which is both larger than my network buffers, and MacTCP read/write calls only take a 16bit integer for their calls, so the async state machine handles looping of the MacTCP calls to ensure everything gets read/written.
PowerPup
Wow, this really is impressive. :D
I'm not too familiar with setting up apache servers, how exactly would I setup one to allow writing to the hosted disk image?
Awesome work so far, really exciting 'cause this is the kind of thing I want to do someday. ;)
bbraun
There's all kinds of crazy apache configs you can do, but I'm testing with mod_dav and a config like:
Code:
DAVLockDB /var/lock/apache2/DAVLock
       Dav On
       Allow from all
But there might other config entries you need to enable mod_dav and give it a lock directory. The specifics of how you do that are somewhat dependent on how your apache is setup.
This also lets anyone have access to the /disks directory, and can write to any file the webserver has permission to write to, so you probably want to check out the apache docs on Allow as well.
techknight
SECURITY ALERT:
Sorry, i just had to. hehe.
might want to add something into the control panel, such as allowing for authentication/htaccess webserver DIRs.
Why? so everyone including joe blow couldnt connect to your server. I guess if its only on your local network, its no big deal. but if you wanted to use this on the go persay, its more important.
bbraun
Added error dialogs to the control panel when it has an issue, instead of just sitting there, and added a read-only checkbox allowing you to mount the file read-only to prevent anything from even trying to write to it. This is useful if you know ahead of time you don't have write access. Unfortunately, I don't know of a good way to determine dynamically if you have write access other than reading a byte and trying to write it back.
I'm starting to think about the interface with the OS. Right now, it doesn't really do well trying to re-mount a disk after you eject it. Part of this is because all the setup is done at driver Open time, and is kind of a one-time setup. The .Sony floppy driver creates the Drive element at driver Open time but marks it as not available. Then on floppy insertion, it marks the disk as available and posts a diskEvt notification. I'm thinking of doing something similar where the driver is Opened by the INIT, which just sets up an unavailable Drive, then the Control Panel would issue Control calls to the driver to inform it to attach to a specific file. I'm not entirely sure how well that'd work, but it's worth some experimenting.
bd1308
If you are using just the GET/PUT commands from HTTP, why would it require DAV being enabled? Are you using the extended commandset of DAV in your implementation? If so, congratulations!
This is interesting because I'm planning on implementing a subversion instance with a subversion hook which will do checksumming of committed files and keep an index of file checksums. This way, i'll immediately know if I have a problem with file X after it sits for a year or two (although I've only had the data corruption issue with Windows 2000 Server, never with CentOS+Samba+Netatalk combo)
LOOM
This is a very cool project! I can see your newest file is from 3th april 2012, but no updates in the thread. What's the latest news, CHANGELOG, TODOs? :)
Have you tried testing it over a network connection for a long period of time? How does it handle network timeout when its mounted?
If you put the extension and software into the system folder on a system floppy it would boot the system with a HDD in 'the cloud'. Much safer than flashing your ROM ;)
olePigeon
I have a couple questions:
Could this be implemented for use with a Disk Copy disk image?
Also, following up on LOOM's idea, would it be possible to couple this with dougg3's ROM and make a network terminal out of a Macintosh II series? That would be totally awesome! You could hold down the N key like on newer Macs and boot your vintage Mac over a network. :D
techknight
Yea, but somehow the PRAM would need to be loaded with some values before the mac would know what image to fetch, Where its at, and possible/if any credentials to get to it.
Maybe default values in ROM, or a special control panel that takes place of "startup disk" and sets that.
Either that, or make a image server that the mac listens to a broadcast message from. Once found, it locks onto the IP from the broadcast originator, fetches a default boot image and off it goes. But this would only work on a local network, or a VPN network.
But all this requires a ROM level network driver. With many many different network card configurations, the network boot code would almost need to be on the network card ROM like in the PC world. So once the DeclRom gets called and loaded, it adds code into RAM to be able to boot from the network with that particular card. Same way SCSI cards do it that allow you to be able to boot from that particular card, as it patches in overtop of the current SCSImanager inside ROM.
You could patch over the .Sony driver in ROM from the DeclRom if it works that way, I dunno. But one would have to look in a book and find out how SCSI cards did it. And then use that code/method to make it work for NICs.
Macs with on board NICs, just find the DeclRom info on that nic and modify it, or just stick it in main ROM and handle it there. But before boot can even happen, you would have to load the NIC DeclRom, then some sort of low-level ROM based network driver/TCP/IP stack.
bbraun
The latest news is I haven't played with this much in the last month.
My belief is I can't get writes reliable with the current approach to things. Reads are totally reasonable, but I've been struggling to get the writes reliable and the more I work on it, the more problems I become aware of.
I currently need to focus on packaging up a read-only release with some of the newer improvements I've been working on.
As for testing with long term connections, the driver creates a new connection for each operation. So each read/write translates to a PUT/GET request on its own connection. It is not using HTTP/1.1 keepalive. So long term idleness isn't really an issue, although efficiency is something else entirely.
There's no particular reason this couldn't be modified to work with a diskcopy image. I'm not familiar with the various disk copy image types, but from what little I do know, it seems reasonable.
The big topic on everyone's mind seems to be netbooting. Believe me, this is at the front of my thoughts.
I don't think this would make a good basis for netbooting. But don't despair, there are plans.
Some background (this might be duplicated elsewhere on the forum, but I'll wing it from memory here again), feel free to skip ahead:
It is my belief Declaration ROMs are a good way to add code/drivers in ROM for booting purposes, even the System ROM. All system ROMs from the Mac II up have a "Slot 0" declaration ROM. Using dougg3's ROM SIMM, adding code to the Slot0 DeclROM should be a relatively easy, non-destructive way to add code/drivers (compared to overwriting the .Sony floppy driver like I was doing with the ROMDisk driver).
DeclROMs are basically a directory structure, each entry being a "resource ID" that can contain multiple attributes. All DeclROMs have a resource that provides a description of the board (name, general type such as NIC/Video/etc). It can have supplemental resources, the declroms I've peeked at typically have one resource for each supported resolution/color depth setting for video cards, and SCSI cards have one resource for each SCSI ID in the chain.
When booting from a slot (nubus, pseudoslot, whatever), the PRAM stores both the slot ID and the resource ID within the declrom. So you don't just boot from a slot, you boot from slot+resource. In the case of a SCSI card, if there is one resource per SCSI ID, that's how you know which of the potentially multiple SCSI IDs attached to the card to boot from.
Additionally, when booting, the Start Manager/Slot Manager doesn't just load the device driver from that resource within the declrom at the designated slot, and try to boot from it. It actually loads and runs a different set of code in the resource. Typically, that code loads a driver from its own resource id, and begins the boot process, but really can do anything it wants. Including looking at currently pressed keys to decide whether it wants to be bootable.
So, although this HTTP Disk driver could easily be loaded in this manner, it uses MacTCP, which isn't in ROM. Adding it to ROM too is a problem for multiple reasons: it finds its self inside the System Folder and loads resources from its self in order to do DNS resolution, it looks on disk for network configuration information, and the real kicker ends up being ethernet drivers.
Most ethernet cards do not have drivers for themselves in their declrom. Ethernet drivers aren't DRVR driver resources at all. They're 'enet' resources. There is a .ENET driver, but that's not the same thing, that's more of a generic interface to the various 'enet' resources.
Ultimately, for a bootable solution I'm thinking the approach taken by others back in the day is the way to go: Implement your own 8390 ethernet driver, and a minimal IP stack in a declrom, and then fetch a disk image (protocol is a mere implementation detail here, supposedly ye olde solutions could fetch an image from tftp or AppleShare), and boot it as a RAM disk image.
As for how to find the image to boot from, this is a problem that has been solved over and over again, all differently. People have used more solutions to that problem than I care to contemplate. That part isn't something I'm terribly worried about, and at the moment would lean towards just using existing DHCP options, falling back on PXE-like default server/file naming conventions.
Plus, with a custom IP stack, making this HTTP disk driver writable would be much easier. It's just a Simple Matter Of Programming, right?
