So... heading wayyy back to this thread, I feel like I've got some sharing of notes regarding what I've done with my B&W now that I have a PowerPC 7410 ZIF and Tiger to play with. Nothing fancy!
Here's what I did:
- Started with Mac OS 9.2.2 (no idea what was the original install media, sorry).
- Installed the Sonnet Encore/Crescendo G4 patch for Mac OS 9 version 2.3.1 to hack the B&W firmware to accept G4 ZIFs again.
- Installed the ZIF ( almost forgot to write down this step! )
- Installed Mac OS X 10.4 Tiger from the version that came on four CD-ROMs by restarting the Mac, holding down the "C" key to boot from CD, and let it install without anything else special. The Startup Disk X control panel wouldn't let me boot from the Tiger CD, I had to reboot with the C key for the Tiger installer to do anything.
- ...After more than 12 hours of Tiger, I got bored of Tiger for being a little buggy, not modern enough like Leopard and not different enough like Jaguar, so I'm in the process of replacing it with Mac OS X 10.2 Jaguar... which also shipped on CDs...
With Tiger, everything worked out of the box with the Sonnet ZIF.
A thread that's nearly twelve years old reports that the Sonnet ZIFs don't need any jumper block changes, and that's consistent with what I've seen. My 7410 ZIF is automatically bumped to run at 500 MHz without any changes.
Jaguar needed a
SonnetCache Enabler 1.4 for Mac OS X to see the Sonnet ZIF's L2 cache, but that's the only other thing that I've seen it needs so far.
In my opinion, Jaguar seems happier on a G3 and early G4. The software that requires Tiger at a minimum really wants beefier GPUs to take advantage of Core Image without taxing Altivec.
EDIT: I have a budget Radeon 9200 in this B&W. It's better than a Rage but it doesn't have the right DX9-era features to make Core Image and Quartz Extreme work. Those are the bits that Tiger wants and Leopard
needs... which explains why some G4 Mac Mini impressions on OS X were so lacking, between the 9200 and the very slow hard drive it came with.
That doesn't help with the web browser problem. The worst tradeoff of Jaguar is that it came with Internet Explorer, with Safari 1.0 introduced with the 10.2.8 combo update. Both are positively ancient in all the bad ways.
I'm coming to the conclusion that recent TenFourFox is too slow for any G3 or early G4 and as far as good Tiger browsers are concerned,
Camino's last release is exactly one year older than Classilla. I'm running every browser with Java and JavaScript turned off and all plugins uninstalled, and the experience of using the modern web is... awful, still. Not awful compared to a Chromebook, awful compared to my PowerBook G4 running Leopard, which already limps along in its own ways when web browsing.
One issue that I'm having with this B&W is that I can't get the keyboard combinations to select between multiple partitions in Open Firmware to work, at least "Option" at boot isn't doing anything. I'm having to switch between Mac OS X and Mac OS 9 through their respective flavors of Startup Disk. This reminds me of a similar problem I had back when I owned a Sawtooth, I'm wondering if I have the keyboard combinations wrong for this early version of Open Firmware.
