I think I just figured it out! I just made a GS/OS boot disk!! So, I put the files onto a flash drive and then put the flash drive onto my Rev. B iMac G3 (which runs Mac OS 9.2) then put those files onto a floppy disk (via a USB floppy drive) then transfer it to a older machine, one with a floppy drive and that can format to Prodos disk (I used a Power Mac 4400/200). Then, on the older computer, you get another 1.44 floppy (preferably one you don't need) and put tape over the hole on the right side of the disk and insert it, it'll ask you if you'll wanna format it to ProDOS version. Then take the first floppy and copy the files from the first floppy and put it onto the second. That should be it!
