ikethederg
Trying to get Classic support and OS 9 running on my late 2002 iBook g3 800mhz. I can't find the install discs with the extensions for classic.
Hi, provide me your mac model.. I will try to find it when I get off work this evening for you. If Macintosh Garden had my 1ghz Titanium G4 original discs, then they should also have the system you own too.I need the original disks for it to actually work
Late 2002 ibook g3 12' 800mhz ati radeon 7500 mobility, PowerBook 4,3Hi, provide me your mac model.. I will try to find it when I get off work this evening for you. If Macintosh Garden had my 1ghz Titanium G4 original discs, then they should also have the system you own too.
No, I don't. I did get it to boot again after a pram reset and os 9 works now.I remember there was an Apple recall on the optical drive on your iBook when it was new 2003? Apple said the replacement optical drive was more reliable, but it would not boot into OS9. Owners had to decide if the upgrade was worth it.
Do you know what optical drive is installed in your iBook?
