doctormistral
Hi all!
I'm from Italy and I'm trying to recover a mac classic logical board that I've previously recovered after a Max bomb in 2012. After a full recap and a lot of cleaning the mac has come back to life but after a while a put it in a box and kept it until 2017. Than i did a check and it was not working anymore but i decided to kept it in the box because no time to dedicate to it.
In these days of lockdown I decided to fix it but it appears much harder than expected!
Latest Symptoms:
Tests done:
I'm running out of ideas and starting to think there is something deeply wrong in this board!!
I'm new in this group but I've read a lot of posts, suggestions, even discovered the existence of schematics and many more ... but I'm stuck...
Find attached some pics of the LB.
Thanks a lot for any suggestion...
Latest Symptoms:
- chessboard video (sometimes messed), regardless (with or without) ram extension board and (with or without) ROM.
- no startup audio,
- until a week ago sometimes connecting the floppy cable and moving it in the connector (like to simulate a bad contact) the mac booted,
now only switch the screen from chessboard to standard desktop - but not boots, nor floppy icon with "?".
Tests done:
- The problem is likely in the LB because putting it in another Classic perfectly working I get the same problem: no sound + chessboard.
- Recapped again the LB
- Voltages are OK +-12V / 5V (regulated from trimmer in the AB)
- Various washes with various products. After one of which I made the situation worse moving sympthoms from 3 -> 3.1
- Rom is OK because boots in the other working Classic
- Unsoldered (hot air desolder) + board cleanup + re-soldered various chips: CPU, RTC, SOUND, VIA, 2x 74F257A -> no change.
- Checked a lot of PCB lines especially DATA and ADDRESSES between ROM/CPU/VIA using the known schematic -> No problems
- The reset signal to CPU correctly rise high after voltage is stable.
- Seems that the RTC is doing nothing: I'm using a multimeter and can't find any frequency in the crystal pins nor in the pins 2, 12,13 of RTC chip. I checked this in the working mac and even here can't find and frequency in the pins 2, 12,13 of RTC but there is some confuse/variable frequency in the crystal (may be my multimeter is not enough sensitive).
