Help setting up Basilisk II for System 6 (Macintosh Plus)
PaultheRoman
New member
I'm getting lost in terms of finding the necessary files needed to set up the emulator, and then configuring it correctly. Can someone help?
slomacuser
For system 6 use mini vMac. Basilisk cant run in 24 bit. Only sys 7 and 8 are working in Basilisk.
GuiBer
New member
Helpful link, but Basilisk can run 7, as noted above.
You're right but, in my opinion, Mini vMac works better for System 7 up to 7.1.1. With 7.5.3 and later it's better Basilisk II, which allows also to modify the screen resolution.
