UltraNEO*
Hiya guys,
Here's the problem...
I have a PowerBook Titainium 867Mhz. I plan to install MacOS 9.2.2, only the original seller didn't supply the original disks and having a huge problem getting any sort of system software on there, that make the system function correctly.
I'm wondering, is it at all possible to extract system files from the original System installler CD's? I believe they're in a odd file format.. I have both the Retail System 9.0.1 disc with the 9.2.2 upgrade. However nether of them will boot the machine. Is there a way to stripstream the two? Anyone know how I can do this?? Tips? or Suggestions?
BTW, I have an rough Idea what should be in the system folder... just don't have the right software to boot the system.
