Giving Classic II something to do
Jon183
Hi everyone,
I have a classic II which is probably my most stable compact mac, I want to actually use it for something, is there a good software suite for making labels? Kind of like MS Publisher. I also want to import modern jpegs and turn them into monochrome pictures for use on labels. What else can you do with a monochrome compact mac for fun?
SE30_Neal
Ha-ha I know the feeling i have a mac se/30 im just upgrading before putting to work. I just brought a scanner for it they’re cheap enough. Pretty much any publishing software will do quark, aldus or software like Claris works or Word would do, try several see which one works for you.
happy fun with your classic :)
MacFox
I'm always trying to find a "purpose" for each of my Macs too.  I mainly use Word 5.1 on my Classic II.  One thing my Classic II can do that my SE can't is convert Word 97/98 files to Word 5 format.  The converter requires an '020 or better, so it won't run on my SE.  Other than that, I had MacDraw II on it for a time, if you're interested in drawing you can check that out.  Pretty much any black and white software that will run on an '030 and doesn't require 256 grays should work on the classic II.
SE30_Neal
I did notice there is a lable only software on macintoshgarden. I do agree MacFox having a use for your machine is needed.
Jon183
Ill reinstall Microsoft Works and will try to use it for assignments somehow, ones that don't need referencing should be fine to work on.
