Ghost in the machine?
mst3k
Greetings,
I've acquired a Power Mac G4 running OSX 10.4.
This machine has a working Zip 250 drive and a DVD-ROM drive.
With a Zip disk inserted and mounted and completely usable an odd thing occurs when I select eject from the menu with ONLY the Zip drive selected.
The Zip disk ejects as it should, but the DVD-ROM drive ejects as well.
This occurs whether there is a disk in the DVD-ROM drive or not. The DVD-ROM drive works fine on it's own.
Ghost in the machine or is the 'eject everything' normal behavior?
mst3k
For those of you thinking the obvious, you were right. No ghost.
A simple conflict set up by incorrect jumper positions on the drive select pins.
I tried 'cable select' on both and it worked. I tried 'master' and 'slave' on each and that worked too.
Boo.
