Hello fellow Mac lovers. This is my first post here. Nice forum, I think I'll stay!
Let's get directly to my problem/question: I acquired a G5 Quad and already did a flush and refill of the lcs. I assembled everything back, repasted the CPUs and did a thermal calibration. Everything works so far, but: CPU 0 is at 47°C in idle while CPU 1 (lower one) sits at only 37°C. So CPU 0 is 10°C hotter. Pumps and fans are all detected and running at normal speeds.
Voltages are at 1.16V at all cores. But the amp readings are different: CPU 0 draws up to 9 amps in idle while CPU 1 only draws 6 amps.
Is this normal behavior? Does CPU 0 maybe do all the OS background work in Leopard while CPU 1 is truly idling along? Or do you have any other explanations?
Greetings and thanks!
