Trash80toHP_Mini
NIGHT STALKER
I guess this should stand on its own, there are a few related threads. Whatever, I'll explain/link later, I've got a couple of questions first.
The questions are heat related, these little Savvios run HOT!
I've got a couple or three options for keeping it cool.
1) It's already sitting on a good heat spreader and as the plan goes another will be in goo contact with it above.
2) For better heat transference, I'm thinking about removing the sticker on top of the drive so I have straight metal to metal contact.
3) I'm thinking in terms of adding a heat sink, possibly one with a fan to the heat spreader/chassis sitting on top of it.
4) The heat sink in the piccie as a stand-in isn't really too tall, if I use it, it'll be a subterranean heatsucker.
I'm leaning toward taking a goodly sized hole saw to the floor pan of tilting tray and the plastic drive sled. I can mod the runners and sled for a short run liftoff or swap 'em out entirely. That way I can arctic Goop the heatsink to to the bottom of the tray where it'll sit next to the internal HDD bay in the basement.
5) The east attractive of prospect of all would be to hack it up to have a fan with airflow all around the little Savvio with it standoffed to the chassis without that patented Apple Sliding PlastiCrap.
I really wanna have it set up so that I can bolt up a pull bar to the mounting holes on front of the cute little drives...
. . . so I can cold swap them in and out just by pulling the RFI shielding off the front. [}] ]'>
Comments? How might each heat transfer scenario work out and do you have any other suggestions?
. . . this is the kind of thing that happens when I've got Thanksgiving all to my lonesome after bachin' it for a few days. [] ]'>
