Emulation: Binaries for Mini vMac 37 with LToUDP
... we're in 2024 and router manufacturers apparently still can't get IGMP snooping working properly. Great.
(and yes, I typed 2023 to start with)
NJRoadfan
This is an older router, but still flawed. So far it:
-Screws up IGMP (including Bonjour)
-Screws up AppleTalk AARP packets
-Has a completely broken RIP implementation
-WAN side flips out and doesn't pass traffic if you have a private range IP (in double NAT situations).
Admiral Ackbar
Thank you! I was able to successfully use this version and an AirTalk box connected to my Mac Plus 4mb (and printer not modem cable) to access a share in Mini vMac. The version of Mini vMac (running on Windows 10) I paid-for didn't have the functionality.
RichCini
I stumbled upon this thread while trying to solve why I don't get sound on any of my builds. I'm building from both 36.04 and 37.03 sources on my Mac (Intel running Sonoma 14.7.2) and the typical command is:
./setup_t -m 512Ke -mem 512K -t mc64 -hres 512 -vres 342 -speed a -magnify 1 -sound 1 > setup.sh && . ./setup.sh && make && plutil -replace NSHighResolutionCapable -string 0 minivmac.app/Contents/Info.plist
The emulators work, there's just no sound, so I must be missing something on my system or I don't have some framework installed. Any help with what I could check for would be appreciated.
Rich
RichCini
If I run the pre-built ones from 2018, they work on my system with sound. If I build from sources, there's no sound. I happen to have a copy of OSX Sierra in a Parallel's VM that's a "virgin install" (meaning nothing added) that I keep for random things like this. I just compiled both 36.04 and 37.03 with the command line above (for 36.04; xcodebuild for 37.03) and it works with sound within the VM and on the host machine.
Based on that, it must be something nutty with my software environment and/or OS version that prevents the sound support from working. While I don't think I'm going to be regularly rebuilding this from sources, it would be nice to figure out what's going on.
Rich
