mvallance
eMate hinge suddenly stiff and display is not bright
Hello. I have had my eMate for 4 years and use it occasionally.
After using today it seems the eMate hinge suddenly became stiff and display is not bright.
I have searched the forum here and found this ..
Perform the hinge fix on it.
viewtopic.php?f=3&t=11313&p=111449&hilit=eMate+hinge#p111449
What is at the hinge fix?
Where can I buy a display ribbon if that needs replacing?
is there a Fixit set of instructions?
thank you.
Michael
thank you.
Michael
