Chopsticks
even on the SE/30 I have trouble with the bluescsi unless its externally powered. this behaviour does change slightly symptomwise depending on the firmware used. obviously overclocked fw wll draw more power on the bluescsi, however I think he mentioned in the video he tried stock fw.Did you try the System Folder from the floppy copied onto the bluescsi? Guessing you did.
Accelerators change the timings of ROM routines, usually it is subsystems like floppy, sound and serial that play up. I haven't seen SCSI problems before, but I don't have a BlueSCSI. The accelerators' ROMs or drivers patch the system to correct the timing issues (but seem to struggle with sound!).
How were you powering the BlueSCSI? Have you done the termination power diode mod, or are you using external power? The SCSI on the Plus is wonky enough that some accelerators provide better, less broken, SCSI implementations.
What versions of the drivers do you have? Have you got GemStart 3.*? I saw the Extreme Systems logo briefly in your video. Generally GemStart 2 is for System 6, and 3 is for 7 and 7.0.1. 7.1 wasn't officially supported. I think the Extreme Systems version supports 7.1.
also im not sure what version of bluescsi ActionRetro used and I haven't followed development of that project in a long time, however it should be noted that those pins on the STM bluepill certainly aren't rated for the sink current the scsi bus puts on each pin. they really should have some kind of bus transceivers....
that could be part of the issue though like you pointed out its not common for the scsi bus to get affected. like you id more see a floppy, sound or even a serial port issue... perhaps testing a few different scsi devices such as a mechanical drive, ZIP drive, scsi2sd etc could norrow down the scsi issues he had in that video
