When i put the my duo 2300c into the original duo dock after it has been sitting for a few weeks it boots just fine and runs for about a minute then shuts down. Each time i start it up after this it runs for an even shorter period of time and eventually does not work at all. When i push the power button it clicks and then the fan spins for a second, then dies. I have replaced "the tick of death" capacitors with 100uf caps. I have also removed the nubus cards, vram, floppy, HD and have had no luck. The powerbook duo does work just fine when not in the dock and is running system 7.6.1. Does anyone else have this problem or know a way to fix it? :?:
