philcollins
Hey y'all,
I'm in the process of repairing a Disk III for this Apple III project I've been cooking with and I'm experiencing a really strange phenomenon. I was wondering if anyone out here on 68kMLA has seen a Disk III do something like this:
When the analog board is screwed into its base, the drive makes a loud grinding noise on any access and the A3 reports an I/O Error. The A3 Confidence Program won't even recognize the disk as being online in this state; however, when I unscrew the analog board and hold it in the air, the disk works just fine, passing all confidence programs.
I've replaced all the ICs on the analog board with tested good ones and have fully recapped all the electrolytics, but to no avail. What's particularly weird here is that, as soon as I as much as gently lay down the analog board on top of its mount during any disk activity, the grinding noise resumes and the disk fails.
It seems like a grounding issue of some sort, but the mount is made out of plastic, so I'm uncertain if that's the case.
Any ideas on what could be cooking here?
Thanks so much for the consideration and all the best!
