Huxley
Hi all! A while back I picked up this gorgeous Apple II from a Craigslist seller. He'd received it from a family friend who worked for Apple back in the 80's, and I think it's an original Apple II case with a II+ Rev. 7 motherboard inside, but I'd love to be corrected if I'm wrong! The model tag on the underside reads "A2S1."
The seller mentioned that he was told that the last time it was used there had been some smoke from the power supply side of the machine - it was shut down, packed away, and not touched for ~30 years. With this in mind, I've decided to get it up and running again. As a precaution, my first steps were to give it a quick blow-out with my handheld air blower, and to install a brand new ReactiveMicro power supply.
The machine is remarkably clean overall, with no obvious signs of damage, abuse, liquid exposure, etc. It does look like the original owner was at least somewhat 'crafty,' as there's a tiny toggle switch installed in-line with the speaker, which I'm assuming is effectively a "mute switch."
Here's the dilemma: with the new PSU installed, when I power it on it will display a pattern of random text, blinking/flickering blocks, and/or shifting garbage.
Here's a simple album with pics. Any idea what would be a good next step to troubleshoot and restore this machine?
- It has never beeped during any of my tests, although at this stage I can't vouch for the functional condition of the speaker and/or the DIY mute switch.
- Removing the Disk II card and/or shifting it to other slots seems to result in a new/different garbage pattern on screen.
- I've used some cotton swabs to carefully dab a bit of De-Oxit Gold onto the legs of every socketed chip I can reach (I haven't disassembled the machine fully, so I can't get to the ones deep under the keyboard yet).
- I've re-seated all the socketed chips - ROM's, RAM, CPU, etc.
- I've left it powered on for a few minutes and felt around the board - the CPU, ROM's and RAM get warm, but I'm not detecting anything I'd describe as "concerningly hot."
