Converting sit to dsk on windows. Please help
Zehlek
New member
I tried search on google and all it comes with is a video which has no sound and very distorted and hard to see. I have Windows Vista and I was wondering if and how to convert an sit to dsk to play mac games on a mini vMac emulator? Thanks in advance for help
Mac128
SIT and DSK are NOT the same thing at all. First you have to unstuff the SIT. Then the resulting item should be a DSK or IMG file. If the contents are loose, you will have to get a disk image, mount it and drag the loose applications into it. You should be able to create a 1.4MB disk image in Windows that mini vMac will read. I suggest you visit the mini vmac site for details as there are a number of resources there for doing just this.
