I wanted to test the Turbo 601 in as many machines as possible, including a IIci, IIvi, IIvx and Performa 600. Maybe IIsi, if possible.
I was sure I had a IIvi among my collection of Macs, but sadly I only have the IIvx and P600 (of this series). I thought I had read that the IIvx and P600 used 33mhz processors on a 16mhz bus, and the IIvi used 16mhz processors on a 32mhz bus, but now I can’t find that info. Everything I find says all 3 are using the same 16mhz bus.
If that is correct, then I don’t “need” a IIvi to test this card.
@Bolle : I have a Sonnet 68040 upgrade for IIsi, with the dual slot adapter board. Can I use that same adapter board to try the Daystar Turbo 601 in a IIsi?
I really want to test in as many machines as possible without risking blowing something up. The Daystar Turbo 601 for 68030 seems to be extraordinarily rare.
What I did find somewhere online last night is that the IIci cache card can be used in a IIvx and P600 but not in the IIvi. I don’t know how or why that would be, and if true shows there’s a difference in the board itself from IIvi to the IIvx.
Also found a thread here from 2017 where members were trying to get a Turbo 601 to work in an SE/30, and it seemed that ROMs for the IIvi would be required somehow to work in an SE/30. The thread also mentions the ROMs for the IIvi are different than for the IIvx. I would think that’s strange isn’t it? Would the ROM on a Centris 650 be different from the Quadra 800 (both Wombat boards)?
