:lol: - your mistake, fundamental, do you actually know how the circuit works? It would seem not.Indeed I might choose to swap CRT yokes becuase that's my business, and colour CRTs are very diff from mono, but that was not being disussed here. But to the average guy wanting to do the job, it can bring complications.the capacitance issue he raises is of no concern; the capacitance is integral with the yoke,
I like how you ask such a question without expounding on why you would think it....do you actually know how the circuit works? It would seem not.
The issue is one of providing information to the OP so that he can get his Mac fixed. The information I gave is correct: There is no incompatibility between the Plus and SE CRTs and yokes at all. He can swap them freely without worries. That's the only information he needed. Your post muddied the waters with extraneous, irrelevant information and correction was therefore needed. Don't take offense at the correction. Our job here is to post helpful information to those who ask for it.I'm not going to enter into a flame war, I can see you are impressed by my knowledge and feel threated, here we go geek wars "I know more than you" )
cue flames...
Well, the link they provided is dead now.Radio Shack part numbers 64-2220 and 64-2223 should be enough to adjust nearly any CRT ever made, but unfortunately, both have been discontinued. Check your local Ratty Shark for stock; the catalog doesn't list these any more but individual stores often have one or two sets.
An alternative to the Ratty Shark set is this set, which costs US$13.97 and, according to Dan, is "pretty well made." A bit pricier, but probably worth it if you can't find tools elsewhere.
After reflecting on your friends' theories a bit further, I think I've figured out what they were thinking. It seems that I've overlooked the possibility of a mismatch in relative humidity specs. If the Aquadag formulations are designed for different RH, then there can be a large fluctuation in flyback inertia, causing an electron pile-up in the 2nd-anode area. But this won't cause any damage to your Mac. True, it might cause electron "whiplash" Bremsstrahlung, but that is a consideration only in esoteric corners of E&M theory (I'm sure your physics teacher can expand on this if you are interested), and has no practical bearing on your repair challenges. So, again, feel completely free to swap crts (but not necessarily deflection yokes) from one compact Mac to any other.I spoke to my physics teacher about the issues pertaining to the CRT compatibility. Although his knowledge on vintage Macs is limited (he was a Commodore guy in his youth, or so I have been told), he states that perhaps the voltage difference that the TV tech was referring to could perhaps be the result of fluctuation in the power supply, or flyback transformer, which is causing an inbalance of some sort.
