clone macintosh's ps/2 ports?
chelseayr
wasn't sure if this should be posted here or in the peripheral section instead...
is the ps/2 port just as good as the adb port (especially to manually select boot drives at chime) or it has its limits even if paired with an older basic non-multimedia keyboard?
had to wonder  about this as I'm trying to resume my interest in wanting to get one particular clone system since last year!
jessenator
I'm not at all convinced* Apple (or Motorola, PCC, et al) ever produced a driver for PS/2 (for MacOS). Those were there for PREP/CHRP compliance on the clones. Apple, even on their LPX-40 (Tanzania) 4400/7220 didn't have the PS/2 populated, unlike Motorola's StarMax line which was the same board, essentially. Just one gesture on how Apple felt about PREP/CHRP, I suppose.
My own (anecdotal) experience on my StarMax (no drivers at all, just plugged in pre-power-on) is that PS/2 mice work rather terribly: horrible click latency to the point where you have to do geriatric clicks (read: hold down longer) to get it to register. And since 3rd party Mac mice were ADB, it's doubtful right button support is enabled at all on a device plugged into the PS/2 port. When I plug in a standard PS/2 mouse the right click just freezes the mouse until you let go… I would also have infrequent cursor position latency, but that wasn't precisely repeatable.
I don't recall my experience testing my Dell PS/2 keyboard, but I'm sure it was similar to the mouse experience. I can test that again, too.
TL;DR MacOS didn't have specific PS/2 driver support AFAIK and have seen in clone maker installation disks, *though I haven't had an image of PowerComputing's MacOS 8 disc to test…
Did Umax ever have a MacOS 8 disc? I know they were still making 603/604 systems which *ahem* might have shipped with a G3 card in a separate box…
paws
I'm quite sure there was no discernible difference between ADB and PS/2 when I was testing my StarMax tower. I'd kind of assume that, for compatibility, whatever is handling PS/2 just turns it into the same kind of data that normally comes in over ADB, and that that's why there's no driver needed.
chelseayr
thanks jessenator and paws, and yeah the adb port is still there so I may as well as rather just use that alone
