It's usually not too difficult with logic board electrolytics, no cap list really needed. Pull the board out and it will probably be mostly 47uF, with perhaps a single or couple of 100uF, 10uF or 1uF.Does anyone have a capacitor list for a Performa 6360?
That makes sense.I don't have computer yet, was hoping to order caps for when it arrives.
The 6300 isn't a road apple, and the 6200 is only slow if you run 68k software. In 2023 there is no reason to be running 68k versions of software.I did the same as you and looked for some pictures of the 6360 LB, but I wasn't able to come up with much. You're right, I'll just have to wait. I have a Performa 6300CD that I was going to recap, but when I was researching the kinds of caps I needed, I read a little more and discovered that it's considered a Road Apple. Apparently the design was idiotic. I was given the 6300CD for free and I guess that's about what it's worth. I'm going to part it out in the hope that the funds will cover what I paid for the 6360. That one seems to be a better machine from what I read.
The SE/30 is a few years older and from the worst era for cap issues. They need recapping on sight. The 6400 isn't the same... yetI just completed a recap job on an SE/30 and that board was a mess.
This is what I was referring to.The 6300 isn't a road apple, and the 6200 is only slow if you run 68k software. In 2023 there is no reason to be running 68k versions of software.
Plus, they're all slow! If we're worried about how slow a 6200 is, get a brand new thread ripper based system
I would own a 6200, 6300 and a 6360 if I could find them cheap. I like that case. It's like a better looking, mini, G3. They're really expandable, even if they do take weird cards.
Sadly they didn't sell 6360s here, but one day I'll make my own with a 5400, 5500, 6400 or 6500 board.
Don't buy one on eBay, they haven't been made in decades.Do you have any advice on where to get a replacement battery? I found one on ebay but not thrilled about paying $30.
Keep the connector and wire in a new battery of choice in the 3 to 4.5v range. Pick something that doesn't leak!
If you get a 3 battery AA box, and put the type of Lithium battery that doesn't leak in it, that should be good.
I wouldn’t part out the 6300 - if it works, sell it as working. Someone will certainly want it, they’re great little desktops. LMK when you do get the 6360 cap values - I’d love to add them to the reference section on my website. A top down image of the board as well would really help.
Location | uF | V |
C45 | k4 47 | 16v |
C46 | k4 47 | 16v |
C25 | k2 100 | 6v |
C34 | k4 47 | 16v |
C51 | k4 47 | 16v |
C6 | k2 100 | 6v |
C9 | k2 100 | 6v |
C7 | k4 47 | 16v |
C10 | k4 47 | 16v |
C8 | k4 47 | 16v |
C14 | f4 22 | 25v |
It's a 6300, the 6360 has a PCI slot, not an LC PDS.Thanks! Is that the 6360 or the 6300? I could use both, pretty sure this is the 6300 but just wanted to confirm. Also, do you know if the 6300 board was used in any of the other 6xxx systems? I know there were a LOT of similarities.
Would you recommend selling me 6400CD here or on ebay? I'm not doing ANYTHING using FB anymore.Thanks!
