Brain dump: (47uf 16v) Capacitor Choices
uniserver
Bi - Polar
Panasonic Radial - 19 cents
http://www.mouser.com/ProductDetail/Panasonic-Electronic-Components/ECE-A1CN470U/?qs=sGAEpiMZZMvwFf0viD3Y3ffldXPLozayEiipLkmNOyc%3d
Nichicon - SMD - 56 cents
http://www.mouser.com/ProductDetail/Nichicon/UWP1C470MCL1GB/?qs=sGAEpiMZZMvwFf0viD3Y3Qai38GTLLzNGCAho5KX0Os%3d
Taiyo Yuden - Ceramic - SMD - 93 cents
http://www.mouser.com/ProductDetail/Taiyo-Yuden/EMK325BJ476MM-T/?qs=sGAEpiMZZMuMW9TJLBQkXnpMKdRe6%2fORaxesfjtxlnQ%3d
Polarized
Lelon - Radial - 4 cents
http://www.mouser.com/ProductDetail/Lelon/REA470M1CBK-0511P/?qs=sGAEpiMZZMtZ1n0r9vR22Z8b58wL7Nwvox6GEikt6wU%3d
Panasonic - SMD - 8 cents
http://www.mouser.com/ProductDetail/Panasonic-Electronic-Components/EEE-1CA470WR/?qs=sGAEpiMZZMtZ1n0r9vR22cS6GEbW2ftocdkiN2ijlcU%3d
AVX - Tantalum - SMD - 24 cents
http://www.mouser.com/ProductDetail/AVX/TAJD476K016RNJ/?qs=sGAEpiMZZMtZ1n0r9vR22f0Jgorj1M1ux2eqZRFky9I%3d
Nichicon - Aluminum Organic Polymer - $1.65 bucks
http://www.mouser.com/ProductDetail/Nichicon/PCG1C470MCL1GS/?qs=sGAEpiMZZMtm5nWh%2fhvnH8k9pXxgWw2sf6TE7yuJMV4%3d
So far I have personally used all these different caps in re-capping main-boards,
They have all given the same initial results.
Anyone have any general commentary they want to add feel free.
I have found the Ceramics are the easiest to install. :cool:
James1095
I would avoid the use of any through-hole caps in SMT applications. The through-hole parts lack a base to distribute mechanical force applied to the capacitor, which can easily tear SMT pads off the board. Other than that, I'm a fan of ceramic and tantalum chip capacitors, both work very well. The organic polymer caps are a good choice for cost-is-no-object restorations where you want to maintain an original appearance.
olePigeon
Tantalum if you wanna save some money, Ceramic if you want idiot proof or own an LC III. ;)
Plus, Ceramic caps come in different colors, including white, which you could then dye to make any color you like. Tantalum are sometimes black instead of yellow.
Brett B.
I knew I should have ordered a whole bunch of those AVX tantalums a while back. Currently out of stock with a 10 week delivery date. xx(
Guess I'll be waiting to do a couple recap jobs, no big deal, have a few monitors and other misc electronics to fix in the meantime.
uniserver
It's just amazing to me what kind of traffic this website gets.
There was thousands available when I posted that link.
This is the first time I have seen those caps out of stock.
