Multilayer Ceramic Capacitors MLCC - SMD/SMT
uniserver
Hey guys looks like the prices on these caps (ceramic) are getting somewhat reasonable.
Any reason why one would not want to use these for mac re-caps?
1206 1uF 50volts Y5V 20%
77-VJ1206V105MXATBC
100: $0.041 http://www.mouser.com/ProductDetail/Vishay/VJ1206V105MXATW1BC/?qs=%2fha2pyFaduiTIQi%252bXN%2flPTfu2sroN4%252b7R%2f6WR780Vf%252bojICQRLxBXA%3d%3d
0805 10uF 16volts X5R 10%
810-CGA4J1X5R1C106K
100: $0.132 http://www.mouser.com/ProductDetail/TDK/CGA4J1X5R1C106K/?qs=%2fha2pyFaduhw4qtzpusLIl7yqTQkkID6BsehGkRIuBmAOjNmzt4yrsli5cVfcE4T
1210 47uF 16volts X5R 20%
81-GRM32ER61C476ME15
100: $0.507 http://www.mouser.com/ProductDetail/Murata/GRM32ER61C476ME15L/?qs=%2fha2pyFaduhqJK%252bxtQCAFPTBslzzU14W0qS0C2uxeWkHskrFu0lM2Uiawe%2f%252boM5k
And Heck, organic polymer for the 220 and 470uf ones too.
Aluminum Organic Polymer Capacitors 220uF 16V 20%
647-PLV1C221MCL1TD
50: $1.38 http://www.mouser.com/ProductDetail/Nichicon/PLV1C221MCL1TD/?qs=%2fha2pyFadugvUXDsuMPlzEyR6ggMApEu3o7l6dvR%252bxrUawYw0%2fmzJ%252bt2pcq2L9X%252b
Aluminum Organic Polymer Capacitors 16volts 470uF
647-RNE1C471MDN
100: $0.536 http://www.mouser.com/ProductDetail/Nichicon/RNE1C471MDN1/?qs=sGAEpiMZZMtm5nWh%2fhvnH%2futA1e94lDyE5NEWX%2f5XSo%3d
Wouldn't this make one bad ass Re-Cap?
_____________________________________________________________
Thread linked: Capacitor Replacement Thread . . .
James1095
They work just fine, in fact they are arguably superior to tantalum in terms of performance and reliability. Only reason I've mostly used tantalum is that they are roughly half the cost of the ceramics. Either one is vastly superior to the original parts.
The original SMT electrolytics are *terrible* capacitors by nearly any measure. I'm not entirely sure why they're as lousy as they are, but the specs are junk across the board. If it uses a SMT electrolytic, the specs are not critical and anything with the same ratings will work fine.
olePigeon
I'm not an electrical engineer, but I don't see why not if they meet the requirements.
Plus, they're ceramic and look nifty. :) If they do work, I'd be tempted to buy a few to to recap my IIci so match my white HDD.
Not to mention that you could probably dye those suckers and make some cool colored caps.
James1095
I've used them, they install nicely, actually even easier than tantalums because they conduct heat nicely and the solder flows easily. They're smaller too so it's easier to get at both sides with an iron to install them in tight places. An added perk is they are non-polarized so you don't have to worry about getting them the right way around. As I mentioned, the only reason I haven't used them widely is cost, in most cases the cheaper tantalum caps are more than good enough. If you don't mind spending a bit more, by all means give the ceramic caps a go, they're very good.
CC_333
I don't know, but it would make one very expensive re-cap! :lol:
It sounds appealing. When I send you my boards for their much needed recaps, you can use these! I'm willing to pay a bit extra if it'll improve the board's reliability over the standard tantalums or electrolytics.
Keep us informed as to the success of your experiments!
c
uniserver
one word, awesome!
Love these caps, they look great once installed.
very easy to install, no worry about polarity :)
Normally i'd have a picture, but HAP's Portable Back-lit board was massively expedited.
I didn't even test it, he received it tonight, and said that its working with flying colors.
So basically these caps should last forever pretty much?
Charles
uniserver
ah just found another great benefit of the ceramic caps, you can stack them eaisly, on top of each other
Double up the Capacitance for use when you may not have a certain value in stock !
