bootable sata, the eternal struggle
luckybob
I've kept my ear to the ground for one of these Frankenstein cards, and I finally found one!  At a steal of a price.
https://www.ebay.com/itm/SIIG-SC-UNS012-USB-2-0-Firewire-SATA-Combo-PCI-Adapter-Card/222969030865?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
For those who dont want to click the link, it is a USB, Firewire, sata combo card.  I'm hoping the sata can be flashed to a bootable version.  the usb will be great, but I couldn't care less about the firewire.
Does anyone have any experience BOOTING this card in a G3 with OS9?  My plan here is to use it in my desktop G3, saving the other 2 slots for VooDoo 2's.  It LOOKS to be the SIL 3112 chipset.  I dont care if the usb runs at 1.1 ( because OS9 )  it will only be used for keyboard/mouse
Trash80toHP_Mini
NIGHT STALKER
Nice find, have you got a 6500 or TAM to test it? That could be the ULTIMATE TAM upgrade with SATA SSD if it could be coaxed to work..
Bolle
I have flashed two of those cards before.
Works just fine in the Macs I could test it in (9600, Beige G3, various G4s)
The two cards had different PCI-PCI bridges and one of them does not play well with OSX. As long as you stick to OS9 that won’t be an issue though.
Pretty sure the card will not work in a 6500/TAM because of the PCI-PCI bridge on there. There was some info on that in the old 3112 flashing thread but it looks like it has vanished.
luckybob
thats good to hear!  you wouldn't happen to have that bios image?  or at least the name of the one you used?
thanks!
Bolle
Just the standard Sonnet/Seritek firmware you can find everywhere. You have to swap the ROM chip as well to one of the three or four chips supported by the Sonnet firmware just like you would have to do on a normal Silicone Image 3112 card.
Trash80toHP_Mini
NIGHT STALKER
I'm suddenly curious about the FireWire 400 option on these multi-port cards under OS9. How does it compare as a disk interface bottleneck to standard (pre-ATA-xx?) TAM/6500/6400 IDE throughput?
Trash80toHP_Mini
NIGHT STALKER
I'm finding a lot of crazy numbers out there, but it looks as though an SSD adapted to FireWire 400 hooked up to your card under OS9 or one of the few FW/USB cards that support the TAM may be faster than TAM's first gen IDE bus. At first look, my Tempo Trio's ATA-66(?) should be  better than an SSD adapted to FW400 on a PCI bridge in my 6360/6400 boards. Your native SATA should be much better, or is that bridged?
I'll never have a TAM, but it would be nice to find  a way to bust through that architecture's IDE bottleneck. 6500 boards I've got and they've got the same 2 slot limitation of the TAM. [}:)]
Cory5412
Daring Pioneer of the Future
Staff member
Forgive, perhaps I missed something, but if this card has a SIL3112 and it is bootable, wouldn't that by definition be better than the onboard IDE?
Firewire would be nice and firewire disks are not that hard to come by, but presuming cable routing wouldn't be an issue, you can connect a SATA disk and use that instead of IDE.
Is IDE that big of a limitation on those machines? I've been using my beige G3 and now that I've got the oriiginal 8 gig disk and it has been fine, even when starting to use a little bit of software from after the 1998 era.
luckybob
yea, by a large margin.  IIRC the G3 has 16.6 mb/s ide.  So with sata capable of almost 10x that...  yes.  in all ways the matter it will be better.
"real world" on other machines I have, I can only get about 75ish MB/s on the standard pci bus.  Things like video, sound, ethernet, take up valuable pci bandwidth.  I'm currently using a pci ide-100 controller with a sata/ide converter and said converter is clunky to say the least, and honestly wiggles its way loose sometimes.  Hopefully this card will let me use a locking sata cable.
trag
Disk performance on the Beige G3 was appalling.  But then, the PATA hard drives that Apple shipped in those machines (at least the one in my G3/300 Minitower) were even slower than the 16.6 MB/s bus.    Just replacing the drive with something more modern is a speed boost.  Adding any PCI disk interface card will be even more of a boost.
IIRC, Apple offered a disk system upgrade by way of an Atto SCSI controller and a small array of fast SCSI disks.
CC_333
They apparently did. My G3 mini tower had a stock-looking SCSI card and (I think) Apple branded 9 GB SCSI hard drive when I got it, but both the disk and the card seemed to die shortly after (it's a shame, too, as there were lots of neat software programs on it; I'd love to try recovering it one day, as maybe the failure was due to the card and not the drive).
It has a regular ATA drive in there now, and as I recall (haven't booted it up in a few years), performance was acceptable. Not earth-shattering, but okay.
c
Unknown_K
Even an ATA-66 PCI card would do well in a Beige G3 MT. I wish I snagged a few more of those Mac ATA cards when they were still around for a few bucks. The Mac compatible SCSI cards are a good option if you can find a decent SCSI disk for them. Apple used so slow drives in their expensive machines back then.
luckybob
Yea, I literally got a pile of 320gb sata2 drives, designed for 24/7 surveillance cameras. (new)
so they are low power, silent, and quick.  considering I'm only using 1/2 the drive, I'm essentially short stroking the drive.  Performance is great and would only be surpassed by the 0ns seek times provided by SSD drives.
Oh, by the way, I got the card today.   has the sst 010 chip.  Ill need to source a 040.  Going to check my pile of broken parts before i run out and buy one.  At the very least I'll install a socket, so I only need to solder it once.
Bolle
Be sure to get a chip supported by the Seritek firmware:
There are two more chips that are compatible but I can't seem to find the info on those anywhere...
Also check if your current chip is a 5V or a 3.3V part. I am not completely sure anymore if I had to move a VCC jumper or not on that card.
luckybob
got my hot air gun out, pulled a socket off a crappy nic and got a socket on the card.  I'll be testing tonight if I screwed anything up.
luckybob
Got the sst040 chips yester from mouser.  Some reason they were in a air-tight static bag.  Raised an eyebrow initially.  usually they are just taped closed, but I plowed ahead.  Inside the bag was a moisture sensor, silicone desiccant pack, and a box.  The box was the size of a deck of cards.  inside was the 3 chips i ordered (I always get spares).  imho total overkill.  Just the box would have been more than sufficient.  the chips were only $1.80 each.  Whatever.
Going to flash teh chip tonight and drop it in my g3 and see how it goes.
