BlueScsi won't boot in a SE
leonardcarvalho
New member
Hey guys
I need help with bluescsi installed on a Mac SE.
It is not loading the system at boot, but it does not return an error in the log. Below the log:
BlueSCSI https://github.com/erichelgeson/BlueSCSI
VER: 1.1-20231116
DEBUG:0
SDCard Info:
Format:exFAT
SPI speed: 50Mhz
Max Filename Length:64
MID:3 OID:SD
Name:SL16G Date:2/2017
Serial:195632360
- HD10_512.hda HDD / 21037056bytes / 20544KiB / 20MiB
0:----:
1: 512:
2:----:
3:----:
4:----:
5:----:
6:----:
Finished configuration - Starting BlueSCSI
tks
davewongillies
You should check out their troubleshooting guide https://bluescsi.com/docs/Troubleshooting
And if that doesn't help at the end of the troubleshooting guide they have links to their own support channels
Hey guys
VER: 1.1-20231116
DEBUG:0
SDCard Info:
Format:exFAT
SPI speed: 50Mhz
MID:3 OID:SD
Serial:195632360
0:----:
1: 512:
2:----:
3:----:
4:----:
5:----:
6:----:
tks
