BlueSCSI no power
Andrew18489
After troubleshooting the new BlueSCSI I got for a while, I Noticed it just died on me. The LEDs don’t come on. I plugged it in the MacroUSB port and nothing happened. Any ideas?
What model Mac? Based on your comment on @jajan547's profile, and repeating what I said there for clarity in the tread :
I'd suggest checking the voltages on your mac. The floppy port is a good place to check the voltages.
An out of spec power rail can cause exactly what you're describing.
