I have an interesting situation. I blew up my IDE boot drive on my 6500 yesterday. I lost access, to the files and with my limited knowledge, decided to replace the IDE drive with a 'new' one. I found a 300 GB Maxtor IDE drive and used a 6500 recover CD (I recently bought it for just this concern) to format and restore my boot drive (I could only format 128 GBs so lost half the drive). I've added a ethernet and USB PCI cards to improve connectivity. I found the driver for the ethernet card so it's now on line on my network but can't get any other laptops (M1 and Win11) on my local network to see the shared folder on the 6500. Yes, the TCP/IP control panel is set to ethernet and to get it's IP information from DHCP. I haven't found a driver for the Internal USB 2.0 PCI card so it's not working right now. To install the driver for the ethernet card was located on my Win11 and transferred it to the 6500 using my floppy. Worked great with no issues.
But, how do I move files between the 6500 and anything else when modern Macs don't support floppies anymore? How do I copy drivers or other files from my modern mac to the 6500? No USB, no SD cards nor FTP file tranfers. For instance, the PowerMac 6500 is only supported to 9.1 but I can use the OS 9 Helper Utility Patch to install 9.2.2 (I have a 9.2.1 CD and the universal 9.2.2 burned to disk) that MIGHT have drivers to activate my internal USB card. But, when I try to get the helper file from my Win 11 laptop, I plug in a USB floppy drive and copy the file to a PC formatted floppy and copy the .sit compressed file into my 6500. I do have the SCSI 100MB zip drive but my only external Zip drive I have is a 250 MB drive with 250 MB Zip media. And the 6500 Stuffit application can't decompress it because (I assume) putting it on a pc-formatted floppy damaged the file. So, I only have my floppy drive, or external SCSI storage like on a BlueSCSI drive. I just wish when I plug in my External BlueSCSI into the SCSI port on the back of the tower, it locks up the Mac. It's like pulling teeth here. So how do I fix my BlueSCSI so it doesn't hang up the 6500 when I plug it in or use floppies to copy compressed drivers? I wish my G3 iMac DV still worked.
Thank you for your time, patience at my log-winded explanations, and support,
Gerry
Gerry
