Blue SCSI V2 SD Cards
9646gt
I've been using 32gb TeamGroup cards formatted either exfat or fat32. If you are reusing a card from something else just be aware you may have issues. On my SE I spent an entire day on here troubleshooting only to find out using the SD card formatting utility from the BlueSCSI wiki was all that was needed to correct the issue. Just make sure to select overwrite format option.
