Why 8.5.1, 8.6 or 9.2.2? Surely those OS's are more suited to the fastest 603evs, 604 and G3s (even early G4s)? Mac OS 8.1 seems pretty lazy (but OK) on my PB 1400c/117 and I wouldn't normally run anything later than 8.1 on my PM 4400/160.When I started this whole mess, the computer was running OS8.5.1 with a boatload of extensions, and I somehow thought it was OS9.2.2. The start-up time was 1:45 from power button to desktop... ugh. So I performed a clean install of OS8.6 plus Speed Doubler 8, and now the start-up time is 1:50.
So that would make it 2.5 x 37.5 = 94MHz.Huh... interesting. It says Machine ID 42, model name Power Macintosh/Performa 6200/6300 series, processor info PowerPC 603e, machine speed 94 MHz. It also reports 48 MB RAM and 256K external L2 cache. ???
What the heck is this?
They use more RAM, and boot a little slower, but generally run faster due to more native code.Why 8.5.1, 8.6 or 9.2.2? Surely those OS's are more suited to the fastest 603evs, 604 and G3s (even early G4s)? Mac OS 8.1 seems pretty lazy (but OK) on my PB 1400c/117 and I wouldn't normally run anything later than 8.1 on my PM 4400/160.
Wow, that's your SSD with the IDE-to-SATA adapter? How can the crummy Conner HD in mine be reporting faster read/write than an SSD?Someone has a cheater board!
It might be the wrong choice, but I was thinking 8.5 or later would perform best since all the operating system code is PPC-native. I suppose I could try dropping back to OS8.1 + Speed Doubler?Why 8.5.1, 8.6 or 9.2.2?
Hmm... The person who I bought this computer from has had it since 1999, when he acquired from a "computer-savvy acquaintance". Maybe it was upgraded, that would fit with the PSU having a 1999 date sticker on it even though this model of computer was discontinued in 1996.So that would make it 2.5 x 37.5 = 94MHz.
Want to suggest another benchmark app? That one complains Norton Utilities 3.2.1 is incompatible with System Software 8.6.Time to benchmark it.
Newer version of the same program is in the Norton Utilities bundle here :Want to suggest another benchmark app? That one complains Norton Utilities 3.2.1 is incompatible with System Software 8.6.
No clue, I'm surprised too. I'm running a very stock install of 8.1 without Speed Doubler or anything else special.Wow, that's your SSD with the IDE-to-SATA adapter? How can the crummy Conner HD in mine be reporting faster read/write than an SSD?
You might be running a 68k version of the disk driver. Newer drivers have PPC code, but they can be hard to get on the disk if the formatting didn't leave sufficient room.No clue, I'm surprised too. I'm running a very stock install of 8.1 without Speed Doubler or anything else special.
I always found that, contrary to popular opinion about "more PPC code in 8", System 7.5.x ran fastest on my 6300 back when vs 8.x...including startup time.When I started this whole mess, the computer was running OS8.5.1 with a boatload of extensions, and I somehow thought it was OS9.2.2. The start-up time was 1:45 from power button to desktop... ugh. So I performed a clean install of OS8.6 plus Speed Doubler 8, and now the start-up time is 1:50.
I'm not doubting your benchmarks. I just know that almost any machine that I use from the PPC era starts up way faster with 7.5 than 8.anything....at least from what I see.My IIci with a 66MHz 601 video benchmarks faster under8.68.5.1 than 7.5, I'm saying it with reason.
10% improvement.
The other potential option is to just get and IDE to SD adapter.I've also heard that those IDE-to-SATA adapters can be a bottleneck. Maybe a factor? I'm curious to try some other IDE drives and see if they're noticeably faster.
I doubt anyone replaced the CPU. It would be easier to do a board swap with a 6300 or 6290, which are the same logic board with a 603e. You wouldn't bother.but what about replacing the CPU? I haven't peeked under the heat sink, but I think the 6200's CPU is soldered down and not socketed. It's a 240-pin chip with 0.5mm pin spacing, packed in tight with many other components. Somebody with the right skills might have desoldered the 603 with hot air and replaced it with a 603e, but it wouldn't be exactly easy.
The 5260/100 is a 100MHz 603 in the exact same logic board. It's the same board in an AIO case.Unfortunately there are no plain 603 benchmarks in that comparison list.
