I want to adjust the height on my B&W Macintosh Classic but can't find the information on which screw/pot to turn... as there are a few... and don't want to turn the wrong one.
you can't hurt anything just experiment and turn the pots left and right (incrimentally) till you find the one that you want... And because its a classic those pots all need to be worked back and forth anyways.
if the AB has not been re-capped ... then you should re-cap it too.. because it needs it.
