Sorry, I forgot to say its hanging because its connected to an ancient ( Emulator-III ) sampler via SCSI that has a HDD in a format the CC cannot see (not visible using SCSIProbe), all devices on the chain have unique SCSI IDs but it still causes the CC to hang. The way it works now is that neither the sampler or the CC will turn on when the other is turned off (both are okay if turned on at the same time, though). So now the only solution if I want to operate them individually is to disconnect the SCSI cable first. I think this can wear out the cable after a while so I want to find another solution for this, I was thinking perhaps this could be done via some software setting in the CC or other program? Or will I need to resort to a physical SCSI switch?
