Asante MacCon daughterboard question
ktkm
Picked this daughterboard up, to use it with my MacCon IIsi/SE30 ethernet card, in the hope I could skip the use of a transceiver since my currently installed daughterboard only has thick and thin connections.
Question is, are they compatible?
Bolle
Looks good. That one will work.
You even got the detachable part that will let you easily install a DB15 monitor port if you want to use an additional graphics card instead of the AUI port.
ktkm
Sweet! Thank you @Bolle ! And nice feature regarding the detachable AUI port! I will put it to good use the day I figure out how to fit my Rasterops card on top of the TwinSpark/Daystar/MacCon configuration.  ;)
