I just got a "broken" Macintosh 512k (the floppy drive just needed its lube replaced) and after buying a stack of software disks from eBay, I can confirm it works 100%. I've been trying to make my own 400k disks from online disk images, but I'm having a bit of trouble doing it. First, I have a PowerComputing clone that I used to try to make a disk. I used one of the known-working 400k disks that I got from eBay to do this. I downloaded a disk image, opened up the stock copy of Disk Copy (it was 6.3.3 I believe), and made the disk. No dice. What happens is that the Mac sounds like it's starting to boot the system with the disk, but then it gets... stuck? It will begin making a constant hum like it's reading the disk (I can make a video if it helps). It will keep doing this until I either turn the machine off, or force the disk to eject.
I did some research, and figured out (from here, no less) that the recommended version of Disk Copy is 4.2 for this purpose. Additionally, I read that this version of Disk Copy should make compatible disks no matter what Mac OS version I'm using (I'm on 9.2). Same outcome.
I then downgraded the clone to Mac OS 7.6.1 (which is the earliest version of Mac OS I could get my hands on for this computer) and tried it again. Same outcome.
I only have one other classic Mac: a Powerbook G3 Wallstreet. I didn't own the floppy drive for it, so I specifically ordered one from eBay to get this working. Tried Disk Copy... same outcome.
Some things that I noticed is that Disk Copy 4.2 states that the disks I'm insterting for copy are "not Macintosh disks" even though I know they are, and they seem to work fine on the 512k. Additionally, and this is really weird, but I made a copy of one of the system disks. I first popped in the known good disk, ejected it, inserted the copy I made, and the 512k is able to read this disk as if it was identical to the working disk. It seems like some kind of filesystem table is being corrupted or unreadable? I don't know.
Has anyone experienced anything like this before? Are my Macs just too new to write these disks?
