Arduino SCSI device - Work in Progress
erichelgeson
A few quick updates:
I have the 1.0-b rev tested and is the final rev. I'm sourcing BluePills now from but everyone seems to be low on stock or jacking up shipping right now. Have a few on order but have had orders cancelled. Supply chain woe's.
On the software side I've rebased the software component on ztto's which added support for different block sizes as well as updated to SdFat 2.x. I've also added a log file and debugging info in case of issues.
I've added instructions and details to my Github repo wiki.
I've sent a few boards and have had a few people order their own all reporting success.
ToDo: design a 3d printed mount for the rev-b - mounting hole changed.
Current stock is have 3 BluePills & 10 boards (2x ztto-v2's, 4x rev-a's, 4x rev-b's). Not taking orders yet but will post soon how I want to divvy up these. Will likely make 3 fully assembled and provide the rest as kits (sans BluePills - which you can buy in low quantity on amazon for an ok price)
androda
Very nice, I have been wondering on the status of ardscsino and forks.  This seems like the best low-cost scsi replacement for older devices, where speed is less of a concern.  Good work.
warmech
Nice! Glad to see this is still marching along - I'd love to finally be able to replace all my dead or dying SCSI drives.
erichelgeson
Quick update - 25 bluepills arrived and are genuine - so I do have a supplier now, though they're a bit more expensive then I'd like, but that seems to be with everything from China right now. I'll have 60 blanks and 30 bluepills ready to ship kits or fully assembled next week (fingers crossed) & already have 15 spoken for. I have a 3D holder designed too that should fits nicely into compact macs or an external case. We'll see how fast the supply goes and I'll guesstimate another run. Will update again once the boards arrive.
badCaps
Cool! I'll take 1 assembled and 1 kit.  If you are sharing the stl file I'll just print my own cases.  Excited to try these out!
wymtb
First of all, thank you very much @erichelgeson!
At the end of last year I ordered some PCBs from China and the other needed stuff from mouser and other suppliers. Seems to be very hard to receive genuine bluepills. Even the supplier that used to send genuine bluepills send me boards with CH32F103C8T6. Recognized this too late after it was already soldered. So keep a close look before soldering and you might also should try to get at least the code flashed in a first step.
As I still had one genuine bluepill I soldered the next one.
Flashing was done with a ST-LINK V2 China clone. But it seemed not to be working, also no logfile was written to SD.
While digging around with the fake bluepill I changed the code to enable debug. And as far as I can see if debug is enabled the serial line must be connected. If not the device seems like it would not be working. Maybe writing to the logfile could be started a little bit earlier indicating that if debug in enabled the serial line has to be connected.
Furthermore at least one harddisk image file has to be placed on the SD-Card. And the file probably has to be named correctly. I took a file I used in the past I wrote with dd to a SD-card for use with scsi2sd. I simply renamed it to HD00_512.HDS and copied over to the fat formatted SD-card.
After I figured all this out bluescsi is working perfectly inside my Macintosh IIcx.
erichelgeson
Glad you got it working @wymtb! I've ran into the same thing and added most of those things to the documentation on the wiki page https://github.com/erichelgeson/BlueSCSI/wiki If you have anything to add to it, please edit the wiki page!
I actually tried to order a fake, but got a real one :) If someone would like to send me a CH32F103C* I could try to debug it.
My kits/assembled ones will be pre-flashed so you wont have to worry about any of this.
wymtb
Should have taken a closer look into the wiki :)
I was not able to flash the CH32F103C8T6 based bluepill from within the arduino ide. But I was able to flash the bin file using STM32 ST-LINK Utility on my Windows 10 laptop. And this device is working too. No idea if there might be any differences in the long run.
erichelgeson
Had a few hours today to poke at the software side and made a 38% improvement in read performance and 27% improvement in write.
Max Read: 990KB/sec
Max Write: 813KB/sec
Avg Seek: 1.01ms
An SE goes from Happy Mac to desktop in 5 seconds flat :)
It verified ExFat support works, but no reason to use it really unless you need drives over 4gb. Note I did not test formatting a 4gb drive.
The Mac Plus as we know has a few oddities with the SCSI spec - I could not get it to boot off of it, but hope to figure it out. Listed as unsupported right now.
Added some various other logging and bumped to the latest SdFat.
PCB blanks will be here on Friday - next weekend I should have the first batch flashed and ready to ship.
SuperSVGA
Have you tried disconnecting pin 40/A15? If that works it might be a unit attention issue.
erichelgeson
Have not, just starting to read up on the Plus - thanks for the tip!
FYI got a bit more performance out of it today - 1012kb/sec read, 900kb/sec write :)
Migrated the project to PlatformIO - so can do live debugging very easily.
Boards came in early today too! I dont have shipping supplies the page up to order, but will be up this weekend - 68kmla discount code and all.
Andrew
Hello @erichelgeson. I am interested in purchasing a pre-assembled kit if one is available, and I am more than happy to help with the project such as trying out new firmware etc.
Nice work, keep it up!
Stefano Baron
New member
Hello!
Wonderful project! Congratulations!
I had an old Mac Plus modded with an internal SCSI hard drive soldering the SCSI cable wires directly on the NEC 5380 IC (SCSI Controler).
This unit was sold long ago, but now I have another beautiful Mac 512k upgraded with the Plus logic board / back case and would like to enroll to buy a kit ou even a blank PCB and help fixing this Mac Plus issue.
Another mod that could fix the issue and worth a try
https://retroguy.blog/2020/01/14/booting-a-mac-plus-out-of-an-external-scsi2sd-card/
Best Regards!
Stefano Baron
erichelgeson
First batch is up for 68kmla'ers - after my "Friends and Family" round there's only a few left. Second batch should be ready next week I hope.
https://gum.co/bluescsi-1b
5x$5 off with code 68kmla
USA only shipping for now - discussing with someone who wants to build them in the EU, so stay tuned!
If you don't want a kit or assembled but would like to chip in towards development you can do so here https://gum.co/EifeC
Dev updates:
Performance up to 1024kb/sec read now.
Allow arbitrary names so you know whats on your images
Allow for setting SCSI Vendor/Product/Version info via config files
Plans:
Daughter board for db25 and powerbook connections.
BluePills are getting scarce and more fakes, looking at other dev boards to port to.
SuperSVGA
Are you still working on a design with just the bare STM32? I've made a few designs but so far they all cost more and require more assembly than just using a bluepill. I'm probably going to put some together anyway just for fun, and they definitely save on space.
sutekh
Fantastic work! Kit order placed. Should be just the thing for my LCIII :)  Thank you!
Out of curiosity, what benchmarking utility is that @Chopsticks? It looks superior to any of the 4-5 I currently have installed, and I can't seem to identify it!
