AppleColor Hi-Res monitor compatibility?
Yoshihide
Hi, first post on this forum.
I have an AppleColor High-Resolution RGB Monitor (the 13" Trinitron display made in the late 80's through the early 90's), which still works and displays a crisp picture.
But the problem is, the picture is distorted (pincushion distortion) when I connect it to a Performa 450 (=LC III) or an LC 475. On the other hand, connecting it to the LC II in which it was bought with back in 1992, it displays a perfect square picture with no distortion.
What I'm wondering here is whether the AppleColor Hi-Res RGB Display is compatible only with certain Macs, and not-so-compatible with some newer Macs (like ones made after its discontinuation in December 1992). I can't seem to find much sources about the AppleColor display on the internet... can anyone suggest a reason for this monitor being picky, or a solution if any?
Thanks.
Scott Baret
My suggestion is to try it with another LCII (or original LC) to rule out the video system in that particular LCII being bad.
Yoshihide
I wish I did have another LC II to test, but I don't. I just tested the monitor on a Power Mac 6500 and displays the same pincushion distortion.
So, there is nothing special/different about how the LC II video circuitry is built compared with other Macs that are compatible with multiple resolutions?
