Rage 128 questions
croissantking
Couple of quick questions, I have a Rage 128 PCI card in my beige G3 with Rev. C ROM and when I use the onboard video it still thinks a monitor is connected to the Rage 128. Is this because the card is faulty?
Also, I can’t get a picture from the Rage 128 on my AppleColor Hi-Res RGB display, even if I set it to 640x480 at 67Hz. Are these two completely incompatible?
Hum, I've used a Rage 128 in a beige G3 with the later 640x480 apple trinitron I swear, I wouldn't have thought that was any different.
What drivers are you using?
croissantking
Just to update on this, the drivers did not help. I don’t think the ATI card even detects the monitor - it’s likely just not compatible.
croissantking
My Rage 128 has some other weird issues (always thinks a monitor is connected, even when one isn’t; causes lockups in Mac OS 10.2.8) so maybe it’s just my particular card. I will try to get hold of another, or ideally, a Radeon.
Why not have a careful look at the board. It's probably a short or a cut trace. People store them in drawers and it damages them.
croissantking
Just to follow up, because it’s nice to tie up old forum posts, I don’t think there’s anything wrong with my Rage card. I’ve pulled out another similar card from a Yikes! G4 and it does the same thing - thinks a monitor is connected when one isn’t, on my Beige.
It’s a bit annoying when I want to use the built-in video and the mouse goes off-screen onto a phantom display. I’m now in the process of flashing a Radeon 7000 PCI so let’s see if it exhibits a similar behaviour.
LaPorta
Just a question: when did the cards start becoming monitor aware? Older Macs just assume there’s a monitor if there’s a card.
croissantking
Is that right? The internal video on the Beige doesn't activate if there's no monitor plugged in. I guess PCI cards are handled differently, then.
LaPorta
I can’t speak to it, I only know that on NuBus machines, it is treated as if a monitor is there if a card is there. Not sure when this was implemented, just curious.
Not on a Beige Mac, or most cards. That was a thing that some early (80s mostly) cards did. Apple cards were always aware if a monitor was there or not and I don't think I've ever seen a Mac PCI video card that reported a monitor when one wasn't connected.
