Yes, although it's just a quick change to the schematic to produce one for the AM27C512 as well.nice work this is the revision 2 right for the later ROMs?
It's no big deal, I'll just have to find something else to use the extras on someday.Awe sorry that happened, did you get it all fixed?
I usually order a good bit because the volume discounts are sometimes as much as 50% off. Either that or buying full reels for that pick and place machine I hope will arrive someday.Ordered quite a bit huh?
Always good to eye the volume prices / standard packaging on Digikey for sure.I usually order a good bit because the volume discounts are sometimes as much as 50% off. Either that or buying full reels for that pick and place machine I hope will arrive someday.
I have to wonder if the designers of the TechStep intended for different connections to be released in the future, considering that the entire IO section on the TechStep is detachable.This is really neat. I had pondered about this quite a while ago. I wonder if new ROMs could be made for other machines, or additional tests could be done. A Network Test would be useful, for example, to test that an ethernet card is functioning. Help rule out it it's MacTCP or the card itself.
