zigzagjoe
This is intended to stack on the interposer board for use with in a quadra with bare metal code. So far I haven't come across much that would warrant a full revision of the board.... but very early days.Is your next version going to have the lights embedded? Or will you stack this on the interposer?![]()
The problem is the emulated storage device's data is currently synthesized on the fly, so the file listing is fixed. I'm definitely thinking that I will at least have the internal log to a log "file", but the main problem is there isn't a graceful way to inform the host of changes (since the host rightly assumes storage devices don't just decide to change their contents for fun) nor is there a way to deal with the host caching data.You could have a text log file shown on the emulated storage device? Could even include the latest status in the filename "log - failed.txt".
I think I'm going to have to do a full USB disconnect and reconnect, breaking the serial connection as well as making the host complain about the drive going away unexpectedly...
