amedeo_68k
Hi, I’m unable to boot my ”emulated” Apple IIe from any floppy via FloppyEmu, no boot device error.
Any ideas ?
Any ideas ?
OK, sorry to ask the obvious. Doesn't the FloppyEMU need to be in "SmartDisk" (or something like that) mode? I don't have mine in front of me to check the various Apple II modes...
Ooo... interesting... I thought the IIe card did support those. Of course, the other option is to load the diskette image onto the Mac and point at that from the IIe control panel... I believe that's possible?Are you sure you load a 5.25” image? I recall the 3.5” are not supported as the Floppyemu emulates a 3.5 drive that’s not supported bij the IIe card
Yes. It emulates bothAre you sure you load a 5.25” image? I recall the 3.5” are not supported as the Floppyemu emulates a 3.5 drive that’s not supported bij the IIe card
No. I think is not possible to use disk image on IIe card. But I could connect floppyemu on Mac floppy. Then apple IIe card can access it.Ooo... interesting... I thought the IIe card did support those. Of course, the other option is to load the diskette image onto the Mac and point at that from the IIe control panel... I believe that's possible?
Aah, you mean the internal connector, right?No. I think is not possible to use disk image on IIe card. But I could connect floppyemu on Mac floppy. Then apple IIe card can access it.
A ProDOS partition on your hard drive, that is. Right?Been a while for me, never used a floppyemu either.
You can use the Macintosh floppy or any smartport connected to the Logic Board.
The Apple II file can be used directly from the hard drive, the file will be handled and the Apple II mode will kick in ( double clicking the file)
The icon is different.
No image is usable, the real thing.
Yes. I have put correct firmwareI also recall you need to have the specific firmware for Apple II installed on the FloppyEmu. It’s a different one than the Macintosh firmware.
?!A ProDOS partition on your hard drive, that is. Right?
oh. Really ? It sounds odd. How it would recognize the image. Should I set type/creator ?Been a while for me, never used a floppyemu either.
