Tashtari
PIC Whisperer
...And want to advance the cause of Science?
So, here's the thing. It's already been well established by Floppy Emu users what Macs with secondary floppy connectors (whether internal or external) that support the HD20 and DCD emulators like the Floppy Emu and my own TashTwenty. What still remains mysterious is what Macs without a secondary floppy connector support it.
Background: All the signals on the Mac floppy interface are shared between all drives in the system except for the drive-enable line. The IWM and SWIM have exactly two of these. The HD20 plugs into the floppy interface, but every Mac ROM known to support the HD20 will only recognize it if it's connected to the secondary drive-enable line, !ENBL2. Even if it's not routed anywhere on the logic board, the SWIM chip always has an !ENBL2 signal, and it can be accessed by clipping onto the appropriate leg of the PLCC (or soldering a wire there). I've found experimentally that the LC II supports the HD20, and now I'm wondering what other machines fall into the same category.
I wrote some code to take each of the ROM images in my collection and extract the .Sony driver. Only a few were exactly identical (the LC and LC II, and the Q610 and Q650) but several had the same size. In the 18K group were the LC, the LC II, the Classic II, and the IIsi, all machines that are known to support the HD20... also in that group was the IIvx, a machine that is not known to support the HD20. I'm wondering whether it secretly can.
This is a long shot, but what I'm hoping for is a brave soul who is willing to open their IIvx (or IIvi as they're nearly identical and probably have very similar or identical ROMs) and connect a Floppy Emu in HD20 emulation mode such that all the signals from the internal floppy connector are routed to the Floppy Emu except the !ENBL signal on pin 14, and use an IC pin clip (or solder, if you're daring) to connect that pin to the !ENBL2 pin on the SWIM (pin 19) and see if the emulated HD20 drive comes up.
Anyone? For Science? Bueller? Bueller? =)
