I'd be looking at the chip numbers starting "341" but I can't quite read some of them and am feeling too lazy to look them all up againAnyone want to take a chance on calling these??
I wouldn't rely on anything on the PCBs themselves - they're just different versions of the same thing functionally, so you could put different ROMs on different PCBs.Also interesting... under the "SHARP" silkscreen... Top two : 98061, 98085. Bottom two : 98391, 98397.
Are you able to get into Open Firmware with a serial port?So I just picked up a Rev. A ROM for my Beige G3 (later motherboard with Rage Pro PCI chip), but it won't boot. I get a chime, but then the screen stays black.
I'm thinking the Rage Pro doesn't like the Video BIOS on the older ROM.
Unless the ROM module is faulty.
Anyone tried this combination?
ATY,mach64_3DUPro
, The older ROM has version 1.49 while the newer ROMs have 1.53.ATY,mach64_3DU
.Are you able to get into Open Firmware with a serial port?
Hold-Command-Option-O-F during startup. I think by default Open Firmware uses keyboard and screen on Beige G3? If the screen doesn't work then maybe you can type:How would I do this?
" ttya" io
I tried the developer link and Googling for how to do this, but came up short.to use the serial port. But you need to connect the serial port of the G3 to the serial port of another computer to use it.
https://developer.apple.com/library/archive/navigation/ didn't work? Click on macOS and search for Open Firmware.I tried the developer link and Googling for how to do this, but came up short.
Would I use a telnet application on the client computer?
How do I set up the second machine so that it displays the beige G3’s output?https://developer.apple.com/library/archive/navigation/ didn't work? Click on macOS and search for Open Firmware.
Open Firmware two machine access for the Beige G3 is limited to serial port. This includes Open Firmware 1.0.5 (PM 7500) to Open Firmware 3.1.1 (B&W G3 1.1f4 BootROM built on 04/09/99 at 13:57:32).
Telnet isn't usable until later versions of Open Firmware (For example the iMac Apple PowerMac2,1 4.1.9f1 BootROM built on 09/14/01).
Ah, found it.How do I set up the second machine so that it displays the beige G3’s output?
I can't draw the connection with what is now being done?Anyone tried this combination?
Interesting idea but only have a Rage 128 and Radeon 7000 to test with.@croissantking have you tried installing a non-ATi PCI video card like an ixMicro TwinTurbo or something? See if video comes up like that?
Have you tried the Radeon 7000?Interesting idea but only have a Rage 128 and Radeon 7000 to test with.
