I'm just wondering about the parallels between the Powerbooks and their PB Duo Cousins. I need to see their release dates, chances are they came out at about the same time.
PB 180 & Duo 270 - Last of the '030s laptops
PB 500's / PB 190 & Duo 280 - The only '040s units
PB 5300 & Duo 2300 - Start of PowerPC Machines
It is known that the PB 190, PB 5300 and Duo 2300 are related to each other and release at about the same time. But there was some time between the PB 500 series with two releases (PB 520 and PB 540) and the PB 190, and the Duo 280 was released somewhere within this time.
And the Reign of the '030 in laptops (some 17 years well into the '040 desktop era) was because of energy concerns and physical size of the '040 not being doable until it was shrunk. I know in some old Dells (Inspirons & Latatudes) PIII Units used the large Desktop PIII in their early releases until Intel shrunk the PIII and more PIII Laptops came out. Not too long ago, I repaired one such Dell and thought to myself, "Damn, they used a full sized CPU in this thing? I swear!" A couple of years later I repaired a younger model and found the PIII there being the smaller one. The problem with both machines was that the CPU Overheated and cracked, though still working, it exhibited a strange behavior: When on, it would run at full speed for a moment, and then slow down to a crawl for 5 minutes and then speed up again only to slow down again in a repeating cycle. Somehow the silicon crystal of the CPU cracked along the clock area on both CPUs. Replacing the CPU fixed them.
