mrpippy
Spent today trying to get my SE/30 working, and I did get it to boot once!!
It's always had the classic horizontal stripes SimasiMac, without any chimes. I replaced all the caps, without any luck.
I was poking at signals today and found that the reset switch is bad--it was around 500 ohms between the terminals without the button being pushed, which must have been causing problems. I removed R5 to disable the reset button, after that it booted to the flashing question mark! I even got a startup chime when I plugged in a speaker.
I then turned it off and wired in Q3 (a 2N3904 for ADB, it had corroded off). After that it won't boot again, it's having the same symptoms:
RESET* is acting odd. Sometimes after powering on it's around 0.7V, and sometimes will goes up to 5V after a few minutes. No change after it goes high though.
Once RESET* goes to 5V, VSYNC goes to 60 Hz.
Also the 5 PALs (UE6, UE7, UG6, UG7, UI6) are all pretty warm after a minute or two. I can keep my finger on them, but they're much warmer than the 68K or other chips.
ROM CS is high, doesn't change. ROM address lines also don't change. OVERLAY is also high.
CPU is socketed but I haven't tried pulling it out. The 16 MHz clock is running also.
Anyone have any ideas for what to try next? I tried pulling the sound chip high (2K between Sony sound UB11 pin 7-15) but no change.
