A Mac IIsi, An iMac, A SCSI2SD Card and Basilisk
Iamanamma
Please help.  I have some failing hard drives on my Mac IIsi's we are using to run our CNC machinery.  We found SCSI2SD adapter cards, and if I can get them to work, it will save us tens of thousands of dollars.
I have read Simon Carr's "idiots guide" on this forum, and it did help some, but I am completely without knowledge and experience with hacking, and I am completely stuck.  I need a "For Dummies" version.
The biggest problem I have right now is I cannot get the IIsi to recognize the SD card as a supported hard drive.  I configured the card with the scsi2sd-util as indicated, but still no luck.
I have been unable to make a floppy disk with the patched version of HD SC Setup 7.3.5.  I have made the patched version, I just have no idea how to get it out of the Basilisk emulator on my iMac and onto a floppy disk.  I have a USB floppy drive.
If anyone is able to help me get through this, step by step, the help would be greatly appreciated.
Here is some additional information on my hardware:  Mac IIsi, needs to be running OS 7.1, iMac running 10.8.6, SCSI2SD v5.1
SCSI2SD has been configured to believe it is a Quantum Fireball.
Compgeke
For the SCSI 2 SD config did you set the vendor and model to the one in the SCSI2SD in a 68k Mac thread, including the spaces before/after? That’s required for the stock drive setup to recognize the scsi2sd.
A really easy way to get the drive setup off the iMac is to use sheep shaver with local disk access enabled so you can copy to/from the computer. Make a 1.44 MB disk image, uncompressed, in disk utility, copy the drive setup, unmourned image, copy image to the local computer, write with favorite utility. If I remember I’ll try and upload one to the thread tonight to make it easier.
Another thing to check on your Iicis is the caps and batteries. Both are known to leak on these systems whether they’re in use or not.
0xABE
Basilisk II has a “unix” drive on the desktop that lets you copy files between host and your virtual Mac. Make sure your files are stuffed (sit) or compressed in a way (hqx/img) to preserve any resource forks.
Iamanamma
@Compgeke, All of our vintage Macs were re-capped a few years ago because of the leakage problem, and I checked the PRAM battery when I opened the IIsi's case.  I did configure the card as in the post by Simon Carr.
I had some minor success after I received a bootable floppy with OS 6.0.8 and Lido on it.  I got OS 7.1 installed, but when I took the scsi2sd adapter boards out of the IIsi and attached it to the SCSI bus of a G4 we keep vintage software on, something happened to the card. It stopped showing up on any SCSI bus, and when I tried to re-format with Lido, I started getting arbitration errors.  A tech from the vendor couldn't figure out why that was happening, and has promised to exchange the board.
I am going to forgo using Basilisk, it's a bit more complicated than I had hoped it would be.  Using the 6.0.8 boot disk is infinitely simpler, and if I can get my replacement board to work, I will definitely NOT put it in the G4.  That's when everything went sideways!
Iamanamma
I received the replacement board from Inertial, and I am still having the same problems.  It doesn't matter which IIsi I put it into, I get an Arbitration error from Lido, while the patched version of Disk Tools tells me it can't find a suitable SCSI drive.  The termination software is definitely turned on.  The message from Disk Tools makes me think that it knows the SD card is there, but for some reason does not think it's an Apple drive, even though I've programmed it the way Simon Carr said to do it.  I can go to David and Steve's blog at www.savagetaylor.com, but it's really heavy on the command line interface, and when it comes to that, I have absolutely no idea what I am doing.
Has anyone had success doing this?  Should I have Quirks mode turned on or off?   The only difference between the screen shot below and what I have done today is I set up my SD card to be 4 virtual hard drives at 2 GB apiece.  I've counted spaces, I've double and triple checked everything.  I am lost.
Udo.Keller
Let's begin with a simple case:
  • Tell us about the IIsi: Does it still contain a hard drive? Does it have external hard drives as well? If yes, what are their SCSI IDs?
  • Identify a SCSI ID not used so far.
  • Go get a new SD card, put it into the SCSI2SD
  • On the SCSI2SD
    enable only one SCSI target
  • assign the SCSI ID identified above to the SCSI target
  • Start Sector = 0
  • check the "Auto" box
  • Sector size = 512
  • limit the size to 1GB
[*]Boot the IIsi with the 6.0.8 boot floppy that contains Lido.
  • Does it see the 1GB hard drive?
Iamanamma
Hi Udo:
I managed to solve this today.  The IISi had no internal nor external hard drives.  The only SCSI ID in use was "7" which was the floppy drive.  The main thing that led me to success was finding out that I needed to have the scsi2sd board connected to the IIsi via SCSI and to my iMac via USB AT THE SAME TIME while I was configuring the card and setting up the "drives.".  Another thing, I made my first partition (virtual drive) really small...20 MB like an actual antique hard drive, and installed my operating system in it.  Third thing, my IIsi seems to absolutely need the molex power cable.  Things really settled down when I installed OS 6.0.8 FIRST, and then installed OS 7.1 over the top.  Now that I have done it once, I am sure I can do it again.  I have two more CNC machines that are suffering from decayed HD bumper syndrome.  Being able to successfully replace the old ProDrives is a God send.
joshc
Glad you got it working, I can’t wait to do the same with my 68k Macs.
I would love to see your setup as it sounds like you are using your IIsi for real work?
Iamanamma
@joshc Yes, I am using the IIsi for real work.  It resides inside a console and controls the motion of a turret press, lining sheet metal up and telling punches where to put holes.
Iamanamma
What exactly would you like to see?  This is a pic of my most recent success.  It's installed in a IIsi, and this particular SD card was 520MB.  I partitioned it into a 20 MB and a 400 MB, leaving some unpartitioned space, which was recommended.  I have now succeeded in replacing the old scsi hard drives with terminally sticky bumpers in two IIci units.  There are some very happy operators in our shop now that they are turning on their consoles and not getting a flashing floppy icon.
joshc
@Iamanamma Unless it's private, it would be neat to see the whole setup you've got working - I just haven't seen many examples of anyone using old Macs for real work recently, obviously a lot of photos can be seen online but its rare to hear of a current scenario where a Mac this old is still a workhorse!
The SD card upgrade looks great, have you noticed any speed improvement?
Iamanamma
The guys who operate the machines are singing the praises of the upgrades.  One of them stopped me to tell me how much faster it is and how he doesn't have to stand there waiting for it to do its thing anymore.  They are ecstatic with the speed boost.
I don't know if I can post pictures of the machinery, the owners tend to be very private.  It is pretty darn cool that this is working for us, and I would love to show it off.
IIfx
!!! Is that PRAM battery a Maxell? If so remove it ASAP. The red color drew my attention. Those leak and destroy the logic board.
congrats on getting the SCSI2SD going
Iamanamma
I don't think so.  I can't ever recall buying Maxell.  Are you sure they're orange?  From what I can see of the part number in the picture it looks like it's an older Omnicel battery.
IIfx
Apple used Maxell from the factory, and they leak acid in an explosive fashion. Fresh PRAM is a very good idea to preserve the system regardless of battery make.
Iamanamma
@joshcDid you see my posts of the machines and our setup?  It came up in a conversation I had under my "Corroded Chip" post.  I posted quite a few pictures.
